Let $I$ be a closed real interval.
Let $f \colon I \longrightarrow \mathbb{R}$ be a real continuous function so it has a global maximum point.
If I say “let $x_0$ be a point of global maximum…”, my question is: am I using axiom of choice?
No, you're not. The axiom of choice isn't relevant for making one single choice.
The axiom of choice only becomes relevant when you have to make infinitely many choices. Some times, when you have to make infinitely many choices, you can give a general rule for how to choose, and apply it to all those choices simultaneosly. The axiom of choice states that even when you cannot find such a rule, it is still possible to make all those infinitely many choices in one go.
No. The set of all points where $f$ attains a global maximum is a closed subset of $I$ and therefore it is a compact set. So, it has a minimum. Therefore, you could, for instance, choose the minimum among the ponts at which $f$ attains a global maximum.
So, even if you had infinitely many functions (possibly with distinct domains) the axiom of choice would not be required in order to choose a point of global maximum for each of them.
