Evaluate $\cos(2\cot^{-1}(32/49))$
What I did for this problem was:
  • Turn $\cot$ into $\tan(49/32)$
  • And I am not sure what I do with the $2*$
I tried multiplying $49$ by $2$ and plugging the values into a reference triangle.
After I had all three sides I just found the $\cos$ of the triangle and used that as the answer but it was incorrect. I also knew i couldn't use any of the double angle formulas because the two is in front of the identity.
The cot is inverse
Where did I go wrong?
bjcolby15
  • 3,599
By a well-known formula you have $$\sin\left(\cot^{-1}x\right)=\frac1{\sqrt{1+x^2}}$$ And, of course, the double angle formula $$\cos2x=1-2\sin^2x$$ Now your solution is straightforward $$\begin{align}\cos\left(\cot^{-1}\frac{32}{49}\right)&=1-2\sin^2\left(\cot^{-1}\frac{32}{49}\right)\\[10pt] &=1-2\left(\frac1{\sqrt{1+\frac{32^2}{49^2}}}\right)^2\\[10pt] &=-\frac{1377}{3425}\end{align}$$
  • Instead of a "well known formual" $\sin\left(\cot^{-1}x\right)=\dfrac1{\sqrt{1+x^2}}$ I'd say $\cot = \dfrac{\text{adjacent}}{\text{opposite}} = \dfrac{32}{49},$ so $\sin = \dfrac{\text{opposite}}{\text{hypotenuse}} = \dfrac{49}{\sqrt{32^2 + 49^2}}.$ – Michael Hardy Nov 25 '17 at 00:05
Use Are $\mathrm{arccot}(x)$ and $\arctan(1/x)$ the same function?
Now if $\tan^{-1}x=y,\tan y=x$
$$\cos\left(2\tan^{-1}x\right)=\cos2y=\dfrac{1-\tan^2y}{1+\tan^2y}=?$$
