Let $x_1,x_2,...,x_n$ be the roots of the equation $x^n+x^{n-1}+...+x+1=0$.
The question is to compute the expression $$\frac{1}{x_1-1} + \frac{1}{x_2-1}+...+\frac{1}{x_n-1}$$ Hence to prove that $$\sum_{r=1}^n \cot \frac{r\pi}{n+1}=0$$
I tried rewriting the expression as $$\sum_{i=1}^n \frac{\bar{x_i}-1}{|x_i-1|^2}$$
I then used the fact that $$x^{n+1}-1=(x-1)(x^n+x^{n-1}+...+x+1=0$$ so $x_i$ are the complex nth roots of unity.Using cosine formula I found that $$|x_i-1|^2=2-2\cos(\frac{2i\pi}{n+1})=4(\sin \frac{\pi}{n+1})^2$$
After substituting this I couldn't simplify the resulting expression.Any ideas?Thanks.
user471651
  • 1,164
    Btw it is easy to note that $\cot(\pi - x) =-\cot x$ so that the sum in question is $0$ (pair first term with last, second term with second last and so on and get $0$) so there is no need of all this complicated argument. The same holds if $\cot$ is replaced by $\cos $. – Paramanand Singh Nov 22 '17 at 14:35
For the first part :
Write $$x^n+x^{n-1}+...+x+1 =(x-x_1)(x-x_2)\ldots (x-x_{n})$$
Take log both the sides
$$\log (x^n+x^{n-1}+...+x+1)= \log(x-x_1) +\log(x-x_2)+\ldots +\log(x-x_n)$$ Differentiating w.r.t. $x$, we get
$$\frac{ nx^{n-1}+(n-1)x^{n-2}+\ldots+ 1}{x^n+x^{n-1}+...+x+1}= \frac{1}{x-x_1}+\frac{1}{x-x_2}+\ldots +\frac{1}{x-x_n}$$
Now put $x=1$
$$\frac{(n)+(n-1)+\ldots + 1}{1+1+\ldots +1}=-\left(\frac{1}{x_1-1} + \frac{1}{x_2-1}+...+\frac{1}{x_n-1}\right)$$
$$\color{red}{\boxed{ \frac{1}{x_1-1} + \frac{1}{x_2-1}+...+\frac{1}{x_n-1}=- \frac{n}{2} }}$$
Jaideep Khare
  • 19,293
@Jaideep Khare already gave a nice answer to first question, namely he proved that, $$\frac{1}{x_1-1} + \frac{1}{x_2-1}+...+\frac{1}{x_n-1}=- \frac{n}{2}$$ where $x_i$'s satisfy $$\color{red}{\frac{x^{n+1}-1}{x-1}= }x^n+x^{n-1}+...+x+1=0$$
It is easy to check that, $\color{blue}{x_k = e^{\frac{2r\pi}{n+1}}}$ with $0\le k\le n $ is easy to see that, $x_k$'s are the roots of the equation $$\color{red}{\frac{x^{n+1}-1}{x-1} } =x^n+x^{n-1}+...+x+1=0$$
Now using: $\sin x =\frac{e^{ix}-e^{-ix}}{2i}$ and $\cos x =\frac{e^{ix}+e^{-ix}}{2} $ one can check that,
$$\cot x =i\frac{e^{ix}+e^{-ix}}{e^{ix}-e^{-ix}}= i +i \frac{2}{e^{2ix}-1}$$ thus,
$$\color{blue}{\sum_{r=1}^n \cot \frac{r\pi}{n+1} = ni+ 2i\sum_{r=1}^n \frac{1}{\displaystyle{e^{\frac{2r\pi}{n+1}}}-1} = ni+ 2i\sum_{r=1}^n \frac{1}{x_r-1} =0}$$
Guy Fsone
  • 23,903
Let's do it without any tricks using standard results from the usual theory of polynomial equations. If $\alpha$ is a root of $f(x) =0$ then $\beta=\alpha-1$ is a root of $f(x+1)=0$. Thus it follows that $y_{i} =(x_{i} - 1)$ are the roots of equation $$(y+1)^{n}+(y+1)^{n-1}+\dots+(y+1)+1=0$$ ie $$y^{n} +(n+1)y^{n-1}+\dots+(1+2+\cdots+n)y+ (n+1)=0$$ ie $$y^{n} +(n+1)y^{n-1}+\dots+\frac{n(n+1)}{2}y+(n+1)=0$$ Further note that if $\alpha$ is a root of $f(x) =0$ then $\gamma=1/\alpha$ is a root of $x^{n} f(1/x)=0$. And therefore $z_{i} =1/y_{i}=1/(x_{i}-1)$ are the roots of $$(n+1)z^{n}+\frac{n(n+1)}{2}z^{n+1}+\dots+(n+1)z+1=0$$ and hence the sum of its roots is $$-\frac{n(n+1)/2}{n+1}=-\frac{n}{2}$$ which answers your first question.
The answer to your second question is based on the fact that the given equation can be written as $$\frac{x^{n+1}-1}{x-1}=0$$ and the roots of the equation $x^{n+1}-1=0$ are given as $$\cos\left(\frac{2k\pi} {n+1} \right)+i\sin\left(\frac{2k\pi}{n+1}\right), \, k=0,1,2,\dots,n$$ The root $x=1$ corresponds to $k=0$ and hence the roots $x_{k} $ of the original equation are given by $$x_{k} =\cos\left(\frac{2k\pi}{n+1}\right)+i\sin\left(\frac{2k\pi}{n+1}\right), \, k=1,2,\dots,n$$ Further we have $$\frac{1}{x_{k}-1}=-i\cdot\frac{1}{2}\cot\left(\frac{k\pi}{n+1}\right)-\frac{1}{2} $$ Since the sum of these roots is $-n/2$ it follows that $$\sum_{k=1}^{n}\cot\left(\frac{k\pi}{n+1}\right)=0$$
Clearly, $x_k\ne1,1\le k\le n$
Let $y_k=\dfrac1{x_k-1}\ne0,1\le k\le n$
$\implies x_k=\dfrac{1+y_k}{y_k}$
Now $\displaystyle0=\sum_{r=0}^nx_k^r=\dfrac{x^{n+1}_k-1}{x_k-1}$
As $x_k-1$ is non-zero finite, $$x^{n+1}_k-1=0$$
$$\implies\left(\dfrac{1+y_k}{y_k}\right)^{n+1}=1$$
$$\binom{n+1}1y_k^n+\binom{n+1}2y_k^{n-1}+\cdots+1=0$$
$$\sum_{r=1}^ny_k=-\dfrac{\binom{n+1}2}{\binom{n+1}1}=?$$
Now as $x_k=e^{2k\pi i/(n+1)},1\le k\le n$
$$y_k=\dfrac1{e^{2k\pi i/(n+1)}-1}=\dfrac{e^{-k\pi i/(n+1)}}{e^{k\pi i/(n+1)}-e^{-k\pi i/(n+1)}}$$
$$=\dfrac{\cos\dfrac{k\pi}{n+1}-i\sin\dfrac{k\pi}{n+1}}{2i\sin\dfrac{k\pi}{n+1}}=?$$
Used: How to prove Euler's formula: $e^{it}=\cos t +i\sin t$?
$\implies e^{-it}=\cos t-i\sin t$
