Few years ago I came accross a paper, or maybe a solution of a problem from a journal (possibly AMM or something like that) in which the following result was proved:
The smallest positive integer that can be represented as a sum of two squares in exactly $2^s$ ways (where $s\geqslant 2$ is a given integer) equals the product of $s-2$ smallest integers of the form $q^{2^l}$, where $q$ is a prime $\equiv 1\pmod 4$, and $l$ a nonnegative integer.
(This is not an exact quote, but my restatement of the result.) I am not sure whether this was the main result of the reference in question, or there were some other results in the same text. Anyway, I tried to find the mentioned reference, but without success. I vaguely recall that the problem is from some journal available on JSTOR (in fact, AMM first comes to mind), but I may well be wrong on that point. Is there anyone who knows what I am talking about?
Thank you very much in advance.
P. S. I am not looking for the proof of the mentioned result, it is not hard to prove it. I am looking specifically for the reference I remember, because I would like to put that reference in a book that I am currently writing.
bbasic
This seems equivalent to the version in Dickson's Intro (1929). Different versions on pages 76 and 80. https://en.wikipedia.org/wiki/Leonard_Eugene_Dickson
Will Jagy
  • 139,541
  • Thank you, but it is not the same thing. These theorems only show in how many ways a given number can be represented as a sum of two squares (which is very well-known). In my question the number of representations is given in advance, and we are looking for the smallest $n$ with that many representations. – bbasic Nov 14 '17 at 22:32
  • @bbasic The exact result you describe does not seem to be the sort of thing that would be the main result of a paper, so an exact reference may be a problem. Note that the smallest number cannot be divisible by $2$ or by any prime $q \equiv 3 \pmod 4.$ After that it depends on what you are counting, primitive representations or not, allowing variables to be zero or negative, or not. I did a version of this at https://math.stackexchange.com/questions/2349068/which-numbers-less-than-5-billion-have-the-most-representations-as-the-sums-of-t/2349955#2349955 – Will Jagy Nov 14 '17 at 23:08
