Possible Duplicate:
How to show $(a^b)^c=a^{bc}$ for arbitrary cardinal numbers?
Let $A,B,C$ be sets. Proof that $\left(A^{B}\right)^{C}\sim A^{\left(B\times C\right)}$ . I found the bijection between two sets, but the proof that it is actually a bijection is too long and complicated to understand. Is there easier way to prove the statement, for example by playing with sets' cardinalities? I know that the equality seems quite obvious, but the sets may also be infinite or empty...
Same question about proof of $A^{\left(B\cup C\right)}\sim A^{B}\times A^{C}$. This statement might be not true (the question was prove or give сounter example. Thanks.
If your argument is really all that long and involved, it’s probably unnecessarily complicated. We have
$$\varphi:\left(A^B\right)^C\to A^{B\times C}:f\mapsto\varphi_f\;,$$
where $$\varphi_f\big(\langle b,c\rangle\big)=f(c)(b)\;.$$
Suppose that $f,g\in\left(A^B\right)^C$ and $f\ne g$; then there is some $c\in C$ such that $f(c)\ne g(c)$. Now $f(c)$ and $g(c)$ are functions from $B$ to $A$, so there must be some $b\in B$ such that $f(c)(b)\ne g(c)(b)$. But then $\varphi_f\big(\langle b,c\rangle\big)\ne\varphi_g\big(\langle b,c\rangle\big)$, so $\varphi_f\ne\varphi_g$, and it follows that $\varphi$ is injective.
Now let $F\in A^{B\times C}$ be arbitrary. For each $c\in C$ let $F_c=\left\{\left\langle b,F\big(\langle b,c\rangle\big)\right\rangle:b\in B\right\}\in A^B$, and let
$$f:C\to A^B:c\mapsto F_c\;;$$
it’s entirely straightforward to verify that $\varphi_f=F$ and hence that $\varphi$ is also surjective.
By the way, it’s not just that these two sets have the same cardinality that’s important: this specific bijection is important in its own right.
The natural bijection from $A^B\times A^C$ to $A^{B\cup C}$ is defined as follows:
$$\varphi:A^B\times A^C\to A^{B\cup C}:\langle f,g\rangle\mapsto\varphi_{f,g}\;,$$
where $$\varphi_{f,g}:B\cup C\to A:x\mapsto\begin{cases} f(x),&\text{if }x\in B\\ g(x),&\text{if }x\in C\;. \end{cases}$$
Note: It’s important to assume here that $B\cap C=\varnothing$.
The details will be quite different, but if you mimic the pattern of the argument that I gave above, you should be able to prove reasonably efficiently that this $\varphi$ is a bijection.
Brian M. Scott
  • 616,228
  • Thanks Brian! I edited the question 2: This statement might be not true (the question was prove or give сounter example, sorry for my inadvertence/ – Denis Turov Dec 05 '12 at 02:08
  • So, I assume the statement is not true and the example is to take sets that doesn't fulfill the condition you mentioned in Note. – Denis Turov Dec 05 '12 at 02:10
  • @Denis: Yes, you should be able to construct a counterexample that way. Try $A={0,1}=C$ and $B={0}$ and compare cardinalities. – Brian M. Scott Dec 05 '12 at 02:18
