I’m trying to find a proof of
$$\frac{1}{\sqrt{1-x^2}} = 1+\frac{1\cdot3}{2\cdot4}x^2+\frac{1\cdot3\cdot5}{2\cdot4\cdot6}x^4+\cdots,$$
which doesn’t need Taylor or Maclaurin series, like the proof of Mercator series and Leibniz series.
I tried to prove it by using calculus, but I couldn’t hit upon a good proof.
Asked
Active
Viewed 124 times
Benedict W. J. Irwin
- 4,321
Gymnast
- 287
- 1
- 5
Are you familiar with the generalized binomial theorem? – Crescendo Nov 06 '17 at 17:32
https://math.stackexchange.com/questions/746388/calculating-1-frac13-frac1-cdot33-cdot6-frac1-cdot3-cdot53-cdot6-cdot – lab bhattacharjee Nov 06 '17 at 17:47
I can use it only when coefficient is natural, because I need Taylor or Maclaurin series to get the rational one. – Gymnast Nov 06 '17 at 22:19
So, labbhattacharjee, I’m sorry it must not at all be what I want to know about ... – Gymnast Nov 06 '17 at 22:21
The general binomial theorem can be proved without the use of Taylor / Maclaurin series but the proof is not quite well known. See this blog post. – Paramanand Singh Nov 07 '17 at 03:55
I believe that an alternative answer to this question is at the site https://math.stackexchange.com/a/4659020 – qifeng618 Mar 14 '23 at 17:27
Since
$$\frac{(2n-1)!!}{(2n)!!}=\frac{1}{4^n}\binom{2n}{n}=\frac{1}{\pi}\int_{0}^{\pi}\cos^{2n}(\theta)\,d\theta$$ due to $\cos\theta=\frac{e^{i\theta}-e^{-i\theta}}{2}$, the binomial theorem (standard form) and $\int_{-\pi}^{\pi}e^{im\theta}\,d\theta = 2\pi\,\delta(m)$, for any $x$ such that $|x|<1$ we have
$$ \sum_{n\geq 0}\frac{(2n-1)!!}{(2n)!!}x^{2n} = \frac{1}{\pi}\int_{0}^{\pi}\sum_{n\geq 0} x^{2n}\cos^{2n}(\theta)\,d\theta = \frac{2}{\pi}\int_{0}^{\pi/2}\frac{d\theta}{1-x^2\cos^2\theta} $$ and by enforcing the substitution $\theta=\arctan t$ in the last integral we get $$ \sum_{n\geq 0}\frac{(2n-1)!!}{(2n)!!}x^{2n} =\frac{2}{\pi}\int_{0}^{+\infty}\frac{dt}{(1-x^2)+t^2}=\frac{1}{\sqrt{1-x^2}}$$ as wanted.
Jack D'Aurizio
- 353,855
Essentially this is using $1/(1-x)=1+x+x^{2}+\dots$ (sum of an infinite GP). It is rather very smart to use this formula and integration to obtain the series for $(1-x^{2})^{-1/2}$. +1 – Paramanand Singh Nov 07 '17 at 03:58
