I need to prove that if X has a countable base, then every base contains a countable base.
I understand that this is a duplicate of another stack exchange question, but I do not know why a given element of the countable base can be expressed as the union of elements of the possibly uncountable base.
I thought that the definition of base simply says that every element of the topology can be written in this way, but not necessarily every subset of the topology.
Asked
Active
Viewed 322 times
HBHSU
- 699
1Of course, if B is a countable, then B cantains the countable base B. The problem is vacuous. Did you read the problem correctly? If so, do not go guessing, ask the source. – William Elliot Oct 29 '17 at 04:55
4The problem as you have stated it makes no sense. Are you sure you copied it correctly? I will take a stab in the dark and guess that you were asked to prove something like this: if the space has a countable base (call it $\mathcal A$) and if $\mathcal B$ is some other (not necessarily countable) base for the same space, then there is a countable base $\mathcal C$ which is contained in $\mathcal B.$ Anyway, it's a true statement, and it's a good exercise for a beginning class in general topology, and it uses some of the same words that you used in your question. – bof Oct 29 '17 at 05:00
