In today lecture we were asked to find an explict solution to the following problem
$$\begin{cases}\Delta u(x,y)=0&\text{in}~~~ \Bbb R^2_+ =\{ (x,y) \in \Bbb R^2\mid y>0\}\\ u(x,y)=0&\text{in}~~~ \{ (x,0) \in \Bbb R^2\mid x>0\}\\ \frac{\partial u}{\partial y}(x,y)=0&\text{in}~~~ \{ (x,0) \in \Bbb R^2\mid x<0\} \end{cases}$$ Really don't any clue to this problem I have to apply the poisson formula. But it failled because the boundary term is not entirely defined on the boundary of $\Bbb R^2_+$.
How can I proceed?
Guy Fsone
  • 23,903
There is a nice explicit solution: $u(x,y)=\operatorname{Im}\sqrt{x+iy}$. This uses the principal branch of square root, for which $\sqrt{x}$ is real when $x>0$ (hence $u$ vanishes there). Being the imaginary part of a holomorphic function, $u$ is harmonic. To see that the normal derivative vanishes on the negative half-axis, note that the harmonic conjugate, $v(x,y)=-\operatorname{Re}\sqrt{x+iy}$, is identically zero on that axis. Thus $u_y=v_x = 0$.
An explicit real-algebraic formula for $u$ can be found here.
As originally written, with both conditions for $x>0$, the only solution is $u(x,y)\equiv 0$. Indeed, one extend $u$ to lower half-plane in two ways:
  • by letting $u_1(x,-y)=u(x,y)$ when $y<0$;
  • by letting $u_2(x,y) = -u(x,y)$ when $y<0$;
Either way, we get a harmonic function on $\mathbb{R}^2 \setminus \{(x,0):x\le 0\}$, since both extensions are $C^1$ across the ray $\{(x,0):x > 0\}$. Since $u_1=u_2$ in the upper half-plane, it follows that $u_1\equiv u_2$ everywhere (if a harmonic function vanishes on an open set, it vanishes everywhere). Thus, $u\equiv 0$.
The same idea can be used to show that requiring both the value and the normal derivative of a harmonic function to be zero on the same, however small, part of the boundary, makes the function identically zero.
  • This is a very interesting problem. Do you have any references or good documentation on using complex analysis to solve Laplace equations? Particularly on how to incorporate the boundary conditions. I know all complex holomorphic functions are harmonic, but not much more than that. – Dylan Oct 30 '17 at 19:07
