I'm trying to find a formula for the general solutions for the equation $ax+by+cxy=d$.
I know the general solutions for the Diophantine equation $ax+by=c$ are as follows: Denote $d=gcd(a,b)$;
  1. A solution exists iff $d|c$
  2. $(x_0,y_0)$ is a solution iff the solutions are exactly $(x,y) = (x_0+nb/d,y_0-na/d)$ s.t $n$ is an integer
For the equation $ax+by+cxy=d$ i have only the first part: i know the equation is equivalent to the equation $(cx+a)(cy+b)=ab+cd$ hence there is a solution iff it is possible to factor $ab+cd$ to 2 factors congruent to $a$ and $b$ modulo $c$.
I know i can factor the right side of the equation to 2 factors in every possible way and check one by one and get all solutions. Is it possible that there is a better way to find the solutions?
Thanks for any help!
$$ax+by+cxy=d$$ $$cxy + ax+by=d$$ $$c^2xy + acx+bcy=cd$$ $$c^2xy + acx+bcy + ab= ab +cd$$ $$ (cx+b)(cy+a)= ab +cd$$ To finish, find all integer products $$ mn = ab+cd, $$ both positive and negative $m,n,$ then take all $$ cx+b = m; \; \; cy+a = n $$ for which both $x,y$ are integers, maybe positive, maybe negative.
Will Jagy
  • 139,541
You can write $$y(cx+b)= -ax+d \Longrightarrow cx+b|-ax+d $$ Now $$cx+d\; |\; \big[a(cx+b)+c(-ax+d)\big] = ab-cd$$ Let $m= ab-cd$ and so $$x\in \Big{\{}{k-d\over c}\in\mathbb{Z}, \;k\,|\,m \Big{\}}$$
nonuser
  • 90,026
