13
I have been using Axler's "Linear Algebra Done Right." In fact I have recommended it here often.
I was wondering if there is a text at that level or higher that uses "kernel" rather than "null space"? And that does not go so far out of it's way to avoid matrices.
Thanks.
Masacroso
  • 30,417
  • 40
    Is "kernel" vs "null space" an issue so important that it would veto the choice of a textbook? Why? Just read all occurrences of "null space" as "kernel". – Robert Israel Nov 22 '12 at 22:39
    Artin's Algebra is very matrix oriented. On the other hand, it is not just a linear algebra textbook. Also, I agree with @RobertIsrael's comment above. – Rankeya Nov 22 '12 at 22:41
  • You're absolutely right, and having studied some algebra after "Axler," I now do that. –  Nov 22 '12 at 22:43
    If it has "Matrix Theory" in the title you may be better off. If not all material is covered, you can switch back to Axler or several other books. – Will Jagy Nov 22 '12 at 22:43
    The entire point of Axler's book is to do things in a particular way. If you would like a book that does it the traditional way (i.e. the "wrong way), there are lots of them. Or do you mean you want a book to use as an alternative to Axler's book, but which is still not done in the traditional way? – Carl Mummert Nov 22 '12 at 23:43
  • @CarlMummert The latter, thanks –  Nov 22 '12 at 23:47
  • Does this answer your question? High-level linear algebra book – user1147844 Apr 26 '23 at 03:24
8 Answers8
39
If Linear Algebra Done Right doesn't work, then try Linear Algebra Done Wrong, by Sergei Treil. This seems to meet both of your requirements.
Bill Dubuque
  • 272,048
  • Thanks very much. Gee, wish I could give you more upvotes. With regards, Andrew –  Nov 23 '12 at 03:03
15
If you want a higher level textbook, allow me to suggest "Advanced Linear Algebra" by Steven Roman.
The text is primarily concerned with abstract vector spaces, but it does treat matrices in detail and uses them when it is natural to do so. It will probably also cover all the linear algebra you need in an undergraduate degree. You can read samples of it here:
http://books.google.com/books?id=FV_s8W58D4UC&hl
http://www.amazon.com/Advanced-Linear-Algebra-Graduate-Mathematics/dp/0387728287
Espen Nielsen
  • 3,863
    I loved working through this book. The writing is amazingly clear and motivated. Unlike Axler, his proof of the spectral theorem does not involve matrices at all. He establishes the structure theorem for modules before covering eigenvectors and canonical forms. Roman doesn't "avoid" matrices, but Axler definitely uses more matrices than Roman does. – wj32 Nov 22 '12 at 23:33
I'm a fan of the book by Hoffman and Kunze. It's a standard, concise, proof-based text.
Potato
  • 40,171
  1. [GSM], Dym, Linear Algebra in Action
  2. [GTM], Roman, Advanced Linear Algebra
  3. Lax, Linear Algebra and its Applications
  4. [UTM], Halmos, Finite-Dimensional Vector Spaces
  5. [UTX], Curtis, Abstract Linear Algebra
These are both highly reputed and depth with high quality.
For simple computations and basic concepts, it could be obtained by any textbook or even lecture notes adequately.
For theory, it could be much more benefited to carefully select highly deep books.
Xingdong
  • 2,091
Out of fairness, I thought I would post this for anyone interested. I recently bought a copy of Axler's 3rd edition. It is substantially better than the 2nd. It includes sections on quotient spaces and dual spaces.
With regard to my prior remarks in the question: the treatment of matrices is much more robust with very explicit notation showing how matrices function as linear transformations.
Initially, I thought the graphics in the formatting were a little extreme, but I have come to appreciate them as the pages are more visually accessible.
Finally the problem sets are enhanced (although I don't know what I will do with 500+ problems) yet many of them are challenging and illustrate applications of the concepts. And their organization at the end of each subsection rather than at the end of each chapter reinforces the material.
There is A Terse Introduction of Linear Algebra, which rapidly overview the subject matter of a typical first course in an elegant way. Particularly, it does prefer the kernels over the null space. A free and legal draft of this book is available at here.
Hooman
  • 3,647
Try Lang's Linear Algebra, which is both concrete and abstract.
lhf
  • 216,483
S. Winitzki, Linear Algebra via Exterior Products (free book, coordinate-free approach)
