As part of a larger problem (showing convergence in distribution of a random variable), I am trying to find $\displaystyle{\lim_{n\to\infty}} \sqrt n \left(\log\left(\frac x{e\sqrt n} + 1\right)\right)$. I know that the answer is $\frac xe$ (via WolframAlpha) but I don't know how to show it.
So far I have tried manipulating the expression to make it amenable to L'Hopital's rule, but this hasn't succeeded; I wind up just getting another indeterminate expression after applying L'Hopital's. Any tips would be appreciated.
StubbornAtom
  • 17,052
Ceph
  • 1,336
    $$\lim_{x\to \infty} \dfrac{\log(1/x + 1)}{1/x} = 1$$. –  Sep 12 '17 at 14:58
  • Maybe use some log properties to break up that $\frac{x}{e\sqrt{n}}$ into subtraction? Possibly combine the 1 and the fraction into a single term then break up into separate logarithms. Good luck! – Jon Staggs Sep 12 '17 at 15:01
  • Set it equal to $L$ and then raise both sides to $e^L=exp(\sqrt{n}\ln(\frac{x}{e\sqrt{n}}+1)$, then solve. – JohnColtraneisJC Sep 12 '17 at 15:01
  • So many different ways to solve this. I would use the taylor expansion of $\log(1+x)$ around zero. – Marc Sep 12 '17 at 15:05
The systematic, "let's not think about tricks and do Taylor series" way:
As $\frac{x}{e\sqrt{n}}\xrightarrow[n\to\infty]{} 0$ for every fixed $x$, we have $$ \log\left(1+\frac{x}{e\sqrt{n}}\right) = \frac{x}{e\sqrt{n}} + o\left(\frac{1}{\sqrt{n}}\right) $$ from which $$ \sqrt{n}\log\left(1+\frac{x}{e\sqrt{n}}\right) = \frac{x}{e} + o\left(1\right)\xrightarrow[n\to\infty]{}\frac{x}{e} $$ where we used the first-order Taylor series for $\log(1+u)$ around $0$.
The more elementary, simpler way (once you recognize a derivative): use $$ \sqrt{n}\log\left(1+\frac{x}{e\sqrt{n}}\right) = \frac{x}{e}\cdot \frac{\log\left(1+\frac{x}{e\sqrt{n}}\right)}{\frac{x}{e\sqrt{n}}} \xrightarrow[n\to\infty]{} \frac{x}{e}\cdot\frac{d}{du} \log(1+u)\big|_{u=0} = \frac{x}{e}\cdot1 $$
Note that this is equivalent to the first method, since the derivative here amounts to first-order Taylor approximation.
Clement C.
  • 67,323
I know you have an answer, but I think there's an easier way.
Let $a = x/e$ and $y = \sqrt n$
$$\lim_{\sqrt n \to \infty} \sqrt n \ln (\frac{x}{e\sqrt n} + 1) = \ln (\lim_{y \to \infty} (\frac{a}{y}+ 1)^y) $$
The latter is a common limit problem, which gives us
$$\ln (\lim_{y \to \infty} (\frac{a}{y}+ 1)^y) = \ln e^a = a = \frac{x}{e}$$
John Lou
  • 2,388
  • With this answer I finally feel that I am able to understand how to reach the solution (rather than merely follow along another's reasoning). Thank you. – Ceph Sep 12 '17 at 17:22
I thought it might be instructive to present an approach that relies on elementary, pre-calculus tools only. To that end, we now proceed.
In THIS ANSWER, I showed using only the limit definition of the exponential function and Bernoulli's Inequality that the logarithm function satisfies the inequalities
$$\frac{x-1}{x}\le \log(x)\le x-1 \tag 1$$
for all $x>0$.
Using $(1)$ with $x$ replaced with $1+\frac{x}{e\sqrt n}$ reveals
$$\frac{\frac{x}{e}}{1+\frac{x}{e\sqrt n}}\le \sqrt{n}\log\left(1+\frac{x}{e\sqrt n}\right)\le \frac{x}{e}\tag2$$
whence applying the squeeze theorem to $(2)$ yields the coveted limit
$$\bbox[5px,border:2px solid #C0A000]{\lim_{n\to \infty}\sqrt{n}\log\left(1+\frac{x}{e\sqrt n}\right)=\frac xe}$$
Mark Viola
  • 179,405
Hint: $\lim_{n\to\infty} \sqrt n \left(\log\left(\frac x{e\sqrt n} + 1\right)\right)=\lim_{n\to\infty}\frac{ \left(\log\left(\frac x{e\sqrt n} + 1\right)\right)}{\frac{1}{\sqrt n}}$, now use L'Hopital's rule.
Arun
  • 816
  • So... you're using L'Hopital rule, a (not-so-elementary) theorem which involves computing $f'(u)$ and $g'(u)$ to compute the limit of $\frac{f(u)}{g(u)}$ in order to find the limit $\lim_{u\to 0}\frac{f(u)-f(0)}{u-0}$? Isn't that a bit... unnecessary, and deeply circular? – Clement C. Sep 12 '17 at 15:12
  • @ClementC. I agree to your comment. – Arun Sep 13 '17 at 04:09
