I am unable to determine for which values of $a\in\mathbb{Q}$ does integer solutions to $$x^2+x+1=a(y^2+1)$$
in the form $(x,y)$ exist.
My initial idea was to set $a=\frac{c}{d}$ to get $dx^2+dx+d=c(y^2+1)$ for $c,d\in\mathbb{Z}$ but I am unsure how to convert this into Pell's equation nor do I know how to apply initial solutions. Any suggestions?
Eric Wofsey
  • 330,363
Arbuja
  • You mean integer solutions, right? – Robert Lewis Aug 27 '17 at 00:58
  • @RobertLewis Yeah, integer solutions – Arbuja Aug 27 '17 at 01:02
  • if we re-express it we can get $dx^2dx+d=cy^2+c$ we then get that both sides need a factor of lcm(c,d) at very least. –  Aug 27 '17 at 01:13
  • At minimum, since $d\mid y^2+1$, you get that $d$ must be the sum of two relatively prime squares. – Thomas Andrews Aug 27 '17 at 02:51
    I'm not sure what you can say, other than that you get those $a$ of the form $(x^2+x+1)/(y^2+1)$. You can say that the only possible prime factors of the denominator are 2 and primes congruent to 1 modulo 4, and the only possible prime factors of the numberator are 3 and the primes congruent to 1 modulo 3. – Gerry Myerson Aug 27 '17 at 03:34
  • @GerryMyerson: Kindly see the solution given by individ. (Though I had to edit it for clarity.) – Tito Piezas III Aug 27 '17 at 10:36
7 Answers7
I'll just speak to the question of how to get from $dx^2+dx+d=c(y^2+1)$ to (something like) a Pell equation: We can go
$d(x^2+x+1)=c(y^2+1)$
$d(4x^2+4x+4)=4c(y^2+1)$
$d(2x+1)^2+3d=4cy^2+4c$
$cd(2x+1)^2+3cd=(2cy)^2+4c^2$
$U^2-cdV^2=3cd-4c^2$, where $U=2cy$, $V=2x+1$.
Now, that's not exactly a Pell equation, since the right side is $3cd-4c^2$ instead of $1$, but there are standard methods for solving this kind of equation (or showing it has no solution).
Gerry Myerson
  • 179,216
  • I will keep searching but if you get hold of these methods, can you add them to your answer? – Arbuja Aug 27 '17 at 23:09
  • I strongly suspect that the question of how to solve $r^2-Ds^2=m$ for given integers $D$ and $m$ has been asked and answered before on this website. Let me encourage you to search the site for questions on Pell's equation. – Gerry Myerson Aug 28 '17 at 05:30
    @GerryMyerson , Although you provided an equivalent equation, I think that finding for which values of $a$ the equation is solvable is not equivalent to the last Pell equation. Instead it's equivalent to characterizing the set of integers $(c,d)$ for which 1) the Pell equation has a solution , 2) the solutions verify $u \equiv 0 \pmod 2c$ and $v$ odd. – Elaqqad Sep 12 '17 at 20:28
  • The 1) is already very difficult ( I know only the characterization for the negative Pell equation) , the second condition seem to be also difficult (just as an example whether the solutions of the Pell equation satisfy some non trivial congruence condition is difficult ). In fact the problem of finding whether there are some solutions of a quadratic equation satisfying some congruence conditions is $NP$-complete , see https://arxiv.org/pdf/math/0611209.pdf – Elaqqad Sep 12 '17 at 20:43
Solutions of the equation:
$$ax^2-by^2+cx-dy+q=0$$
you can record if the root of the whole: $k=\sqrt{(c-d)^2-4q(a-b)}$
Then using the solutions of the equation Pell: $p^2-abs^2=\pm1$
Then the formula of the solution, you can write:
$$x=\frac{\pm1}{2(a-b)}(((d-c)\pm{k})p^2+2(bk\mp(bc-ad))ps+b(a(d+c)-2bc\pm{ak})s^2)$$
$$y=\frac{\pm1}{2(a-b)}(((d-c)\pm{k})p^2+2(ak\mp(bc-ad))ps-a(b(d+c)-2ad\mp{bk})s^2)$$
Edited:
For the specific case
$$x^2+x+1 = a(y^2+1)$$
let,
$$a = \frac{u}{v} = \frac{m^2+mn+n^2}{m^2+n^2}$$
Then,
$$x = \frac{mp^2+2m\color{red}u\,pq+(m+n)uv\,q^2}{n} $$ $$y = \frac{mp^2+(2m+n)\color{blue}v\,pq+muv\,q^2}{n} $$
and $p,q$ solve the Pell equation,
$$p^2-uv\,q^2=1$$
where one can easily set $n=1$ to get integer $x,y$.
individ
  • 4,301
  • +1 Your solution works, though I added the *Edit* to give an illustrative example. – Tito Piezas III Aug 27 '17 at 10:34
    Sorry, I don't see how this tells you the values of $a$ for which there is a solution. How do you know whether there is a solution for, say, $a=19/13$? – Gerry Myerson Aug 27 '17 at 11:20
  • @GerryMyerson $m=2$ ; $n=3$ – individ Aug 27 '17 at 11:23
    Sure, but to find that, you have to solve $m^2+mn+n^2=(m^2+n^2)a$. How do you know, for given $a$, whether you can solve that? Is it any easier than knowing whether you can solve $x^2+x+1=(y^2+1)a$? How would you know whether you can solve it when $a=19/17$? – Gerry Myerson Aug 27 '17 at 11:27
  • @GerryMyerson $X=x+s$ ; $Y=y+t$ And solve the more simple equation. To root $k$ was an integer. Can you solve the equation and choose them such that $q=0$ – individ Aug 27 '17 at 11:54
  • Sorry, I don't understand. Can you do it for $a=19/17$, please? – Gerry Myerson Aug 27 '17 at 12:35
  • @GerryMyerson Not every equation has a solution. In your case none. You can make this change and make sure that no matter how simplified. The problem will always boil down to some Pell equation has no solutions. – individ Aug 27 '17 at 13:15
    @individ Can you add to your answer how to determine for which values of $a$ there is a solution. – Arbuja Aug 27 '17 at 13:27
  • @individ could you explain it more? – Davood Aug 28 '17 at 11:24
  • @Famke I do not understand. What else is there to explain? And so everything is simplified. – individ Aug 28 '17 at 13:02
Surely a zest of Galois theory could do no harm.
1) Consider first the equation with rational parameter and variables : $x^2+x+1=a(y^2 +1), a, x, y \in \mathbf Q^*$ (1). With $i^2=-1$ and $j^3=1$, (1) is equivalent to $a= N_3(x-j).N_1(y-i)^{-1}$, where $N_n$ denotes the norm map of $\mathbf Q(\sqrt -n)/\mathbf Q$. The natural question is then how to characterize the elements of $\mathbf Q^*$ which are products of two norms as above. This is a purely Galois theoretic exercise (see e.g. Cassels-Fröhlich, ex. 4.4, p. 358) : Let $K$ be any field of characteristic $\neq 2$. An element of $a \in K$ is a product of a norm from $K (\sqrt b)$ and a norm from $K(\sqrt c)$ iff $a$, as an element of $K(\sqrt bc)$, is a norm from $L=K(\sqrt b , \sqrt c)$ (2). In our case where $\mathbf Q(\sqrt -1)=\mathbf Q(i)$ and $\mathbf Q(\sqrt -3)=\mathbf Q(j)$, (2) is equivalent to "$a \in \mathbf Q (\sqrt 3)$ is a norm from $\mathbf Q (\sqrt 3)(i)$", or "$a$ is a sum of two squares in $\mathbf Q(\sqrt 3)$", say $a=(r+s\sqrt 3)^2 + (t+u\sqrt 3)^2$. Since $a \in \mathbf Q$, a straightforward calculation shows that the latter condition is equivalent to $a$ is of the form $r^2+t^2+3(s^2+u^2)$, with $r, s, t, u \in \mathbf Q$ such that $rs=-tu$ (3). Summarizing : (3) is equivalent to (3b) $a= (m^2+mn+n^2)/(\mu^2 +\nu^2)$, with rational parameter and variables. Cp. the edit of @Tito Pezias III.
2) Let us apply this approach to the special expression of $a$ given by (1). Elementary calculations show that the relation $rs=-tu$ in (3) boils down to $(2x+1)y=0$ and we have two different cases which correspond each to a single normic equation : (i) $y=0$, $a= x^2+x+1= N_{3} (x-j)$ ; (ii) $x=-\frac 1 2$, $3 a^{-1}=4(y^2 +1)= N_{1}(2(y-i))$. Let us finally come back to the original question, with $x, y \in \mathbf Z$. In case (i), $a$ is a norm from $\mathbf Z[j]$, but this is only a necessary condition. In case (ii), $3 a^{-1}$ is a norm from $\mathbf Z[i]$, i.e. $3 a^{-1}$ is a sum of two squares of integers, but again this is only a necessary condition; actually the inequality $3/4a\ge1$ cannot hold if $a\in \mathbf Z$. In the end, the integrality condition imposed on the variables $x, y$ seems rather irrelevant. A more natural condition could be that $x, y\in \mathbf Z$ and $a\in\mathbf Q^*$ is defined up to a square, see (3b).
Edit : Because of the OP's uncertainty, I checked again the "elementary calculations" in part 2) of my answer... and I found a sign error which completely destroys the conclusion, so there is no reduction to two normic equations in one variable. I replace 2) by 3) and 4) below, following the same method but getting a different final result. I put in another answer because it seems that typo difficulties appear when the post is too long.
    And where is the formula for the parametrization of the solutions ? – individ Sep 01 '17 at 13:28
    What solutions ? The OP did’nt ask for solutions, but for a criterion on the parameter $a$. Anyway, since the problem is reduced to normic equations on one variable, it’s trivial to give all the solutions once the criterion is met. Consider e.g. the case called (i). Computing the solutions $x$ of the quadratic equation by means of the usual formulas, the criterion for $a$ is that $a\ge 3/4$ (for the discriminant to be positive) and $4a-3$ is the square of a rational (for the rationality of the $x$’s ). – nguyen quang do Sep 01 '17 at 14:30
  • What kind of a comment is this ? – nguyen quang do Sep 01 '17 at 15:38
  • I said the same thing. And you still said that is just. The problem is reduced to the Pell equation. Its solvability and sets the required coefficients. The author of the question do not like what happens. He hopes to obtain another solution, and another solution can not be! – individ Sep 12 '17 at 08:10
  • No, I don't agree, unless you explain to me why the equation $F(x,y):=ax^2-by^2+cx-dy+q=0$ is solvable iff the "discriminant" $(c-d)^2-4q(a-b)$ is a square. Generally speaking, you cannot reduce a polynomial equation $F(x,y)=0$ to $f(t)=0$ if $F$ is not homogeneous. Here it even seems to me that you consider only the particular case $x=y$. The edit by @Tito Pezias III appears to confirm this. If I am wrong, please show me, but in mathematical terms, not like the last time. – nguyen quang do Sep 12 '17 at 10:28
  • If You don't want to listen, then prove useless. Offer the best approach. The conditions of the problem require all the same to write the parameterization of the coefficients. My approach gives a parameterization. If you are prompted to another form of parameterization of coefficients - so I'm wrong. – individ Sep 12 '17 at 10:39
  • Again, is this a mathematical answer ? – nguyen quang do Sep 12 '17 at 11:45
Here are the announced corrections to my first answer.
3) Beforehand we must come back to the original question : "For which values of $a\in \mathbf Q^*$ do integer solutions to the equation $x^2+x+1=a(y^2+1)$ (1) exist ?" As pointed out by @Gerry Myerson, this formulation does not make much sense (just take $a$ to be a quotient of the desired form), so I guess that the OP actually meant : "What can we say about the integer solutions of this equation (1) when they exist ?" Let us first study the rational solutions of (1) as in part 1). The solutions to the more general equation (3b) are parametrized by equation (3) , which is just a way to express that $a=N(z)$, where $N$ is the norm map of $\mathbf Q (\sqrt 3)(i)/\mathbf Q (\sqrt 3)$ and $z=(r+s\sqrt 3) + i(t+u\sqrt 3)$. If we fix $a$ and a solution $z_0$, all the solutions to $a=N(z)$ will be of the form $z=Z z_0$, with $N(Z)=1$ (this amounts to determine the pre-image of $a$). The solutions of the latter normic equation are in turn parametrized by $R^2+T^2+3(S^2+U^2)=1$ (4), which expresses the representation of $1$ by a $4$-variable quadratic form. There is a well established theory for that (local- global principle, Hilbert symbols, etc., see e.g. CF, op. cit.), but let us use our previous parametrization. To simplify the notations, write $z=[r,s,t,u]$ when $z=(r+s\sqrt 3) +i(t+u\sqrt 3)$, and analogously $Z=[R,S,T,U]$. Then $z=z_0Z =[r_0R-t_0T+3(s_0S-u_0U), r_0s_0+s_0R-u_0T-t_0U, t_0R+r_0T+3(u_0S+s_0U),t_0S+u_0R+r_0U+r_0U+s_0T] (5)$. A not very enlightening parametrization, but note that there is obviously an infinite number of solutions (in (4), just take $U=S=0$ and solve $R^2+T^2=1$)
4) Switching from the general equation (3) to the original equation (1), we adapt slightly the argument of 3) to exploit the particular expression of $a= N_3(x_0-j)/N_1(y_0-i)$ (notations of (1))= $N((x_0-j)/(y_0-i)$. Put $z_0=(x_0-j)/(y_0-i)$; note that by identification one can take $(y_o^{2}+1)z_0 = [y_0(x_0 -\frac 12), \frac 12, x_0+\frac 12,- \frac {y_0}2]$ (6). To get all the rational solutions $(x,y)$, the approach in 3) works without any change. To catch the integral solutions, use (5) and (6), although the computations are not very instructive.
Remark on the Pell-like equation. Putting $z=x+\frac 12$, equation (1) becomes a "Pell-like" equation $z^2-ay^2=a- \frac 34$ (7). But the difficulty is that $a$ appears on both sides; this is related to the OP formulation as discussed at the beginning of part 3). To go on, take $a$ as a parameter given by a solution $(z_0,y_0)$ of (7). There are then two possible approaches :
(i) Algebraically, as in part 3), we are led to solve a normic equation $N(z-y\sqrt d)=N(z_0-y_0\sqrt d)$, where $d=a-\frac 34$ and $N$ is the norm map of the quadratic extension $\mathbf Q(\sqrt d)/\mathbf Q$. By Hilbert's 90 (or direct computation) any element of norm $1$ in such an extension can be written under the form $(e-f\sqrt d)/(e+f\sqrt d)$, and we are brougt back to parametrize $(x,y)$ from $(z-y\sqrt d)/(z_0-y_0\sqrt d)=(e-f\sqrt d)/(e+f\sqrt d)$ by identification. This seems rather neat, but it's actually not, because $a$ is hidden under two disguises, $d$ and $(z_0, y_0)$. Besides, the symmetry in calculations is broken by the eviction of the fields $\mathbf Q (i)$ and $\mathbf Q(j)$, which played such a prominent role in parts 1) and 2).
(ii) Geometrically, the homogeneous form of (7), say $aY^2 + dT^2 = Z^2$, is the equation of a projective conic $C$ defined over $\mathbf Q$ and admitting a rational point $M_0$ (coming from $(x_0, y_0)$). Algebraic geometry then tells us that $C$ is isomorphic to the projective line $\mathbf P^1(\mathbf Q)$. The isomorphism is given by drawing the line joining $M_0$ to some fixed well chosen point of the projective plane $P^2(\mathbf Q)$, and then taking its intersection with $ P^1(\mathbf Q)$ (embedded in $P^2(\mathbf Q)$ as a coordinate axis). This is exactly the same kind of parametrization as for, say, the pythagorean triples. However the final parametrization does not look neater than (i).
I just wanted to see just a few integral values of $a$ that work...( I know it asks for $a \in \mathbb{Q}$ ) $$x^2+x+1=a(y^2+1)$$ $$(2x+1)^2+3=4a(y^2+1)$$ $$\text{pell type equation} \qquad \to \qquad [2x+1]^2-a[2y]^2=4a-3$$ $$\alpha^2-a\cdot \beta^2=4a-3 \qquad \bigg{|} \qquad \alpha=2x+1 \qquad \beta = 2y$$
$$\implies$$
$$x=\frac{\alpha-1}{2}$$ $$y=\frac{\beta}{2}$$
$$\begin{align} & \underline{a \implies (\alpha_n, \beta_n) \to (x_n,y_n)} \\ & 3 \implies (6,3) \to \notin \mathbb{Z^2} \\ & \implies (21,12) \to (10,6) \\ & \implies (78,45) \to \notin \mathbb{Z^2} \\ & \implies (291,168) \to (145,84) \\ & \ \ \qquad \qquad \vdots \\ & 4 \implies (7,3) \to \notin \mathbb{Z^2} \\ & 7 \implies (635, 240) \to (317, 120) \\ & \ \ \qquad \qquad \vdots \\ & \vdots \end{align}$$
With $a \in \mathbb{Q}$ as the OP suggested:
$$d(x^2+x+1)=c(y^2+1)$$ $$d(2x+1)^2+3d=4c(y^2+1)$$ $$\text{pell type equation} \qquad \to \qquad d \cdot [2x+1]^2-c \cdot [2y]^2=4c-3d$$ $$d \cdot \alpha^2-c\cdot \beta^2=4c-3d \qquad \bigg{|} \qquad \alpha=2x+1 \qquad \beta = 2y$$
$$\implies$$
$$\begin{align} & \underline{(c,d) \implies (\alpha_n, \beta_n) \to (x_n,y_n)} \\ & (7,1) \implies (635, 240) \to (317, 120) \\ & \vdots \end{align}$$
You need the equation. $$f(X^2+X+1)=e(Y^2+1)$$
To present in General form. To use this formula. For this we need to make the change.
$X=x+s$ ; $Y=y+t$
The equation then takes the form.
$$fx^2-ey^2+f(2s+1)x-2ety+f(s^2+s+1)-e(t^2+1)=0$$
You need to use the formula to solve this equation.
Solvability is reduced to the solution of this equation.
$$k^2=(c-d)^2-4q(a-b)$$
$$k^2=((2s+1)f-2te)^2-4(f-e)((s^2+s+1)f-(t^2+1)e)$$
Then the solution can be written as.
$$e=p^2+(2s+1)pn+(s^2+s+1)n^2$$
$$f=p^2+2tpn+(t^2+1)n^2$$
$$k=(2t-2s-1)p^2+2(t^2-s(s+1))pn+((2s+1)(t^2+1)-2(s^2+s+1)t)n^2$$
The solution is given @Тито Piezas III a special case of the given formula.
individ
  • 4,301
This is just an oversized comment.
I certainly don’t disagree with any of the methods given, but I’ve just noticed some values of $a$ can be easily excluded by modular considerations. I expect this is just so obvious that it’s not worth mentioning, but here goes.
My assumption is $a=\frac{c}{d}$ where, critically, $gcd(c,d)=1$. If $x^2+x+1=u$ and $y^2+1=v$, then $a=\frac{u}{v}=\frac{c}{d}$.
Although there are a huge number of modular constrains, the most useful (IMHO) are when $$c\not\equiv 0{\pmod j}$$ $$j=(2,5,11,17,23,29,41,47…)$$
I conjecture that the primes $(3n-1)$ follow http://oeis.org/A003627, but I’ve not had time to check.
$$d\not\equiv 0{\pmod k}$$ $$k=(4,3,7,11,19,23,31,43,47…)$$ I conjecture that the primes $(4n+3)$ follow http://oeis.org/A002145, but again I’ve not had time to check.
Old Peter
  • 1,357
