Edit: I have simplified the following argument, removing the `approximation' component. The essence of the proof is unchanged, and some more detail is added.
It is not hard to see that $g \geq f^2$ a.e. is equivalent to the statement that for any $\phi \in L^\infty(\mathbb R)$, we have that
(*) \, \, \langle \phi, g \rangle \geq \langle \phi, f^2\rangle \, ,
where $\langle, \rangle$ denotes the dual pairing of $L^1$ and $L^\infty$. To see, at least, that $(*)$ implies $g \geq f^2$ almost surely, set $\phi = \chi_{\{ g < f^2\}}$, so that $\langle \phi, g \rangle < \langle \phi, f^2 \rangle$ holds if $g < f^2$ on a positive measure set, contradicting $(*)$.
Indeed, we'll check that $(*)$ holds directly for nonnegative $\phi \in L^\infty(\mathbb R)$. For signed $\phi$, the same is true, as one can decompose into negative and positive parts.
Assuming $\phi \in L^\infty(\mathbb R)$ is nonnegative, we now check $(*)$. To start, observe that $\sqrt \phi \cdot f_n$ converges weakly to $\sqrt \phi \cdot f$ weakly in $L^2(\mathbb R)$. Moreover, it is a general fact that if $\psi_n \to \psi$ weakly in an $L^2$ space, then $\liminf_n \| \psi_n\|_{L^2} \geq \| \psi \|_{L^2}$ (check this if you don't believe me : P).
Plugging in,
\liminf_n \int \phi f_n^2 \geq \int \phi f^2 \, .
The RHS is clearly $\langle \phi , f^2 \rangle$. The LHS is
\liminf_n \int \phi f_n^2 = \liminf_n \langle \phi, f_n^2 \rangle = \lim_n \langle \phi, f_n^2 \rangle = \langle \phi, g \rangle \, ,
since $f_n^2 \to g$ weakly in $L^1$.
