Continuing my search of an integral expression for the sequence:
$$a_s=\sum_{n=0}^s {s \choose n} \frac{B_n}{n!}$$
(Where $B_n$ is the $n$th Bernoulli Number, $B_1$ is taken to be $\frac{1}{2}$ and $s$ must be a positive integer, see my other post) I came across the following development, which may be incorrect, since there is numerical evidence to think so. I would be interested in finding the flaw and trying to correct it (if possible) to get a correct result.
Let's start by pointing out the fact that, by the definition of binomial coefficient:
$$\sum_{n=0}^s {s \choose n} \frac{B_n}{n!}=\sum_{n=0}^\infty {s \choose n} \frac{B_n}{n!}$$
Then, since:
$${s \choose n}= \frac{1}{2\pi} \int_{-π}^π e^{itn}(1+e^{it})^s \, dt$$
We have that:
$$\frac{1}{2\pi} \sum_{n=0}^\infty \int_{-π}^π e^{itn}(1+e^{it})^s \, dt \frac{B_n}{n!}$$
Up to here, everything seems to work fine.
Then, as the sum is absolutely convergent for positive integer $s$, say
$$\frac{1}{2\pi} \sum_{n=0}^\infty \left | \int_{-π}^π \frac{B_n}{n!} e^{itn}(1+e^{it})^s \, dt \right | <\infty$$
We are allowed to interchange the sum and the integral operators (by the Fubini/Tonelli theorems, see this other question) to get:
$$\frac{1}{2\pi} \int_{-π}^π (1+e^{it})^s \sum_{n=0}^\infty e^{itn} \frac{B_n}{n!} \, dt$$
By the Generating Function of Bernoulli Numbers, and since for any complex $z$ and integer $n$, $e^{zn}=(e^z)^n$,
$$\sum_{n=0}^\infty e^{itn} \frac{B_n}{n!}=\frac{e^{it}}{1-e^{-e^{it}}}$$
So that our original function/sequence can be expressed as:
$$\frac{1}{2\pi} \int_{-π}^π (1+e^{it})^s \frac{e^{it}}{1-e^{-e^{it}}} \, dt$$
The problem is that, fom example, setting $s=3$ in our original sequence (the sum), we would get $a_3=\frac{11}{4}$, but the integral will equal $1$. This error continues for all other values of $s$ computed.
Any help with this? Where is the flaw and how could it be solved?
Thank you very much.
