I am trying to derive a proof of the associative property of addition of complex numbers using only the properties of real numbers.
I found the following answer but was hoping someone can explain why it is correct, since I am not satisfied with it (From Using the properties of real numbers, verify that complex numbers are associative and there exists an additive inverse):
\begin{equation} \begin{aligned} z_1 + (z_2 + z_3) &= (a + bi) + [(c+di) + (e+fi)] \\ &= (a+bi)+[(c+e)+(di+fi)] \\ &= [a+(c+e)]+[bi+(di+fi)] \\ &= [(a+c)+e]+[(bi+di)+fi] \\ &= [(a+c)+(bi+di)]+(e+fi) \\ &= [(a+bi)+(c+di)]+(e+fi) \\ &= (z_1+z_2)+z_3 \end{aligned} \end{equation}
I justify step 1 by the definition of complex numbers, step 2 and 3 by commutativity in R, step 4 by associativity in R, step 5 and 6 by commutativity in R.
I don't see how step 2 and 3 are commutativity in R. Wouldn't these steps require commutativity and associativity in C as well? For example, in step 2, I am presuming the author of the proof did the following rearrangement:
\begin{equation} [(c + di) + (e + fi)] \\ [c + di + e + fi] \\ [c + e + di + fi] \\ [(c + e) + (di + fi)] \\ \end{equation}
But doesn't the following rearrangement
\begin{equation} [(c + di) + (e + fi)] \\ [c + di + e + fi] \\ \end{equation}
require associativity in C? And doesn't the following
\begin{equation} [c + di + e + fi] \\ [c + e + di + fi] \\ \end{equation}
require commutativity in C?
There are some other steps I am confused by as well, like step 4 only requiring associativity in R when clearly there is an associativity in C occurring on the right end of the equation.
Can anyone provide insight into why this proof is correct?
