Question: When performing a simple Singular Value Decomposition, how can I know that my sign choice for the eigenvectors of the left- and right-singular matrices will result in the correct matrix without just guessing and checking?
If it makes things easier, feel free to restrict your answers to just real-valued or real-valued, square matrices.
Context
Consider the matrix $$A=\begin{pmatrix}2&-4\\4&4\end{pmatrix}$$ which has the left-singular matrix $$AA^T=\begin{pmatrix}20&-8\\-8&32\end{pmatrix}$$ and the right-singular matrix $$A^TA=\begin{pmatrix}20&8\\8&32\end{pmatrix}$$ The eigenvalues for both matrices are $36$ and $16$ (meaning the singular values of $A$ are $6$ and $4$, respectively). The normalized left-singular eigenvectors are $$\textbf{u}_{36}=\frac{1}{\sqrt{5}}\begin{pmatrix}1\\-2\end{pmatrix}\ \ \ \textbf{u}_{16}=\frac{1}{\sqrt{5}}\begin{pmatrix}2\\1\end{pmatrix}$$ and the normalized right-singular eigenvectors are $$\textbf{v}_{36}=\frac{1}{\sqrt{5}}\begin{pmatrix}1\\2\end{pmatrix}\ \ \ \textbf{v}_{16}=\frac{1}{\sqrt{5}}\begin{pmatrix}-2\\1\end{pmatrix}$$
With these in hand, we can construct the SVD which should look like this: $$A=U\Sigma V^T=\frac{1}{5}\begin{pmatrix}1&2\\-2&1\end{pmatrix}\begin{pmatrix}6&0\\0&4\end{pmatrix}\begin{pmatrix}1&2\\-2&1\end{pmatrix}$$
However, if you actually perform the matrix multiplication, the result is $$U\Sigma V^T=\begin{pmatrix}-2&4\\-4&-4\end{pmatrix}= -A \neq A$$
Since the normalized eigenvectors are unique only up to a sign, one resolution to this problem is to choose $$\textbf{u}_{36}=\frac{1}{\sqrt{5}}\begin{pmatrix}-1\\2\end{pmatrix} \ \ \ \ \textbf{v}_{16}=\frac{1}{\sqrt{5}}\begin{pmatrix}2\\-1\end{pmatrix}$$
which produces the correct SVD $$U\Sigma V^T=\frac{1}{5}\begin{pmatrix}-1&2\\2&1\end{pmatrix}\begin{pmatrix}6&0\\0&4\end{pmatrix}\begin{pmatrix}1&2\\2&-1\end{pmatrix}=\begin{pmatrix}2&-4\\4&4\end{pmatrix}=A$$
This begs the question: How was I supposed to know that I had chosen the wrong sign convention for my eigenvectors without checking it by hand?
I have a suspicion that the correct sign convention corresponds to the sum of the components of the eigenvectors being positive (and if they sum to zero then the topmost component should be made positive), but this seems like a pretty arbitrary condition despite it holding for several examples that I have checked.
