This is related to a question I asked here except in this case, I am not asking about the total (complete) ring of fractions. I am asking how to find all possible rings of fractions up to isomorphism for all possible denominators.
Specifically, I am asking for the cases when the rings in question are
  • $R = \mathbb{Z}_{p}$, where $p$ is a prime. (Note: This is NOT the p-adic integers. This is the set $\{0, 1, \cdots, p-1 \}$ of integers modulo a prime $p$.)
  • $R=\mathbb{Z}_{p^{2}}$, again, where $p$ is a prime.
I know that when $R = \mathbb{Z}_{p}$, which is a field, the only multiplicative subgroups are the zero subgroup, $U(\mathbb{Z}_{p})$ (the units of $\mathbb{Z}_{p}$), and of course $\mathbb{Z}_{p}$ itself (although I don't know how to prove this).
When we are discussing the total ring of fractions, the set $D$ (sometimes called $S$) of denominators consists of all non-zero, non zero divisor elements of $\mathbb{Z}_{p}$. However, here, I am asked to consider ALL possible denominators. When $D$ contains $0$, what I get for my ring of fractions is the zero ring, correct (so this would also include the case when $D$ is the whole ring?)? When $D$ is the set of units, then I have the total ring of fractions, and I have, by the question I linked, that $D^{-1}\mathbb{Z}_{p} \simeq \mathbb{Z}_{p}$? Is any of what I'm reasoning here correct?
But what about thee case when $R = \mathbb{Z}_{p^{2}}$? What are all the possible sets of denominators in this case? Recall that the set of denominators just has to be a sub-semigroup. So maybe even for the case where $\mathbb{Z}_{p}$, I'm not including all the possible sets of denominators!
Please help, I am very confused. Thank you.
Where I'm getting stuck is - I don't know how to decide what all the $D$'s should be that I need to check. Because inversion by units doesn't change anything from the complete (total) ring of fractions, I suppose I should just consider $D$'s containing zero divisors and a $D$ consisting of just $0$ itself? Then, how do I figure out what they're isomorphic to?
  • @BillDubuque can you explain more? I need to consider all possible sets of divisors. So how do I know that I've considered them all? What are they? –  Jul 08 '17 at 22:06
  • You know that inverting units does nothing. So it remains to consider what happens when you invert the zero-divisors like $,ap.\ $ – Bill Dubuque Jul 08 '17 at 22:09
  • @BillDubuque do you get the zero ring when you do that? Because isn't that the case when 1=0, and so you have to have the zero ring? –  Jul 08 '17 at 22:12
  • Post your argument as an answer and we will give you feedback (or elaborate in your question where you get stuck). – Bill Dubuque Jul 08 '17 at 22:15
  • $U(p)$ is a cyclic group of order $p - 1$. For example with $p = 5$ the group is isomorphic go $Z_4$ which has more than two subgroups. For instance ${1,4}$ is a subgroup of $\mathbf{Z}/5$ with two elements. – Trevor Gunn Jul 08 '17 at 22:17
  • @T.Gunn BillDubuque seems to be saying that it doesn't matter - comes out to the same thing except now I also need to consider the case for zero divisors. –  Jul 08 '17 at 22:18
  • @ALannister Did you cover inverting zero divisors? – Trevor Gunn Jul 08 '17 at 22:20
  • @T.Gunn in detail? Not really. There was just a point where we glossed over what happens if zero occurs as a member of the set of denominators. –  Jul 08 '17 at 22:21
  • @ALannister The general theory is (for localizing at $S$) to set $\frac{x}{s} = \frac{x'}{s'}$ if there exists $r \in S$ such that $r(s'x - sx') = 0$. Does that look familiar? Then if $s \in S$ is a zero divisor and $sx = 0$ you have $\frac{x}{1} = \frac{0}{1}$ because $s(1 \cdot x - 1\cdot 0) = 0$. – Trevor Gunn Jul 08 '17 at 22:23
  • @T.Gunn yes, I allude to that in my "answer" below. I made it community wiki, so please, feel free to edit. –  Jul 08 '17 at 22:27
  • @T.Gunn also, why is it called "localizing"? –  Jul 08 '17 at 22:29
  • @T.Gunn I posted an answer finally. I'm still not sure how to explain in terms of $r(s^{\prime}x - sx^{\prime})=0$ how if $0 \in S$ (or what I call $D$), then $S^{-1}R$ is the zero ring. If you wouldn't mind posting the reason why either as a comment to my answer or as a separate answer, I would be so incredibly grateful. (If you posted it as a separate answer, I would accept your answer and not mine). –  Jul 09 '17 at 21:17
  • @T.Gunn I hate to bug you some more, but if you get a chance, can you take a look at another question I posted?: https://math.stackexchange.com/questions/2352954/showing-isomorphism-between-two-rings-of-fractions –  Jul 10 '17 at 01:46
  • $R = \mathbb{Z}_{p}$, $p$ prime:
First, note that since $p$ is prime, $\mathbb{Z}_{p}$ is a field; i.e., $\mathbb{Z}_{p}$ has no zero divisors. I.e., $\forall m \in \mathbb{Z}_{p}$ where $m \neq 0$, $\exists n \in \mathbb{Z}_{p}$such that $mn = nm = 1$ -i.e., every nonzero element of $\mathbb{Z}_{p}$ is a unit.
Now, suppose $D$ consists only of units, then $D \subseteq U( \mathbb{Z}_{p})$. Also, note that $\mathbb{Z}_{p}$ has the identity. So, we apply the following result:
Proposition - Let $R$ be a commutative ring and $D$ be a nonempty multiplicative subsemigroup of $R$. Then the following is true:
  1. The map $\phi: R \to D^{-1}R$ defined by $$ \phi(x) = \frac{xy}{y}\, \text{for some}\,y \in D. $$ is a ring homomorphism.
  2. If $0 \notin D$ and $D$ has no zero divisors, then $\phi$ is a monomorphism.
  3. The image $\phi(x)$ of every element $x \in D$ is invertible; i.e., $\phi (D) \subseteq U(D^{-1}R)$.
  4. If $R$ has the identity and $D \subseteq U(R)$ then $\phi$ is an isomorphism.
to conclude that the map $\displaystyle \phi: \mathbb{Z}_{p}\to D^{-1}\mathbb{Z}_{p}$ defined by $\displaystyle \phi(x) = \frac{xy}{y}$ for some $y \in D$ is an isomorphism. Thus, in the case when $D$ consists only of units, the ring of fractions is $D^{-1}\mathbb{Z}_{p} \simeq \mathbb{Z}_{p}$.
Second, suppose instead that $0 \in D$. In order for the pairs $(x,y)$, $(x^{\prime},y^{\prime}) \in R \times D$ to be equal, there must exist some $z \in D$ such that $$ (xy^{\prime}-yx^{\prime})z = 0.$$
Now, according to my notes, this guarantees that $D^{-1}R$ must be the zero ring, but I am not sure why in terms of $(xy^{\prime} - yx^{\prime})z=0$ that is true. If someone could explain that to me either in the comments or in a different answer, I would be most appreciative.
So, to summarize, in the case that $0 \in D$, $D^{-1}\mathbb{Z}_{p} = \{0\}$.
  • $R = \mathbb{Z}_{p^{2}}$, $p$ prime:
In the case that $R = \mathbb{Z}_{p^{2}}$, the set of units is the set of all $m \in \mathbb{Z}_{p^{2}}$ such that $\gcd(m, p^{2}) = 1$.
So, suppose first that $D$ consists only of units of $\mathbb{Z}_{p^{2}}$. Then, $D \subseteq U(\mathbb{Z}_{p^{2}})$, and we note that $\mathbb{Z}_{p^{2}}$ has the identity. Therefore, by the proposition given in the first bullet point, the map $\phi: \mathbb{Z}_{p^{2}} \to D^{-1}\mathbb{Z}_{p^{2}}$ defined by $\displaystyle \phi(x)=\frac{xy}{y}$ for some $y \in D$ is an isomorphism. Thus, in the case when $D$ consists only of units, the ring of fractions is $D^{-1}\mathbb{Z}_{p^{2}} \simeq \mathbb{Z}_{p^{2}}$.
Second, suppose that $0 \in D$. By the remarks in the first bullet point, again, this is the case where $D^{-1}\mathbb{Z}_{p^{2}}$ is the zero ring.
Third, suppose that $D$ contains a zero divisor. Now, zero divisors of $\mathbb{Z}_{p^{2}}$ are multiples of $p$.
Since $D$ is a multiplicative semisubgroup, if $ap \in D$ where $ap$ is a multiple of $p$, then $D$ contains $(ap)\cdot (ap) = (ap)^{2} = a^{2}p^{2} = a^{2} \cdot 0 = 0$.
So, if $D$ contains a zero divisor, it also contains $0$ itself, which degenerates to the case where $0 \in D$; i.e., in this case also, $D^{-1}\mathbb{Z}_{p^{2}}$ is the zero ring.
    I will use slightly different letters to make clear which elements belong to $D$. We have $\frac{x_1}{s_1} = \frac{x_2}{s_2}$ if and only if there exists $r \in D$ such that $r(s_2x_1 - s_1x_2) = 0$. If I am allowed to take $r = 0$ then I have $0(s_2x_1 - s_1x_2) = 0$. This is always true regardless of what $x_1,x_2,s_1,s_2$ are. Thus all fractions in $D^{-1}R$ are equal. If you have a ring where every two elements are equal then that ring is the zero ring. – Trevor Gunn Jul 09 '17 at 21:30
  • The rest of your answer reflects a good understanding of the problem. – Trevor Gunn Jul 09 '17 at 21:45
  • @T.Gunn thank you for everything! –  Jul 09 '17 at 23:16
