Inspired by Geometric interpretation of the determinant of a complex matrix, I ask the following related questions.
The complex determinant is determined up to a global scaling factor by the fact that it is multilinear and skew-symmetric. Let us try to understand the phase of the determinant. For that purpose, let us restrict our attention to $G = U(n)$. Let $E = G \times U(1)$ be the trivial $U(1)$ bundle over $G$. Let $T$ denote a maximal torus of $G$; to fix the ideas, let us assume it is the one consisting of all diagonal matrices in $G$. Let $N(T)$ denote the normalizer of $T$ in $G$. $N(T)$ is the semi-direct product of $T$ with the symmetric group $S_n$ ($S_n$ is the full permutation group on $n$ elements). We can now say that the determinant is a global smooth section $s$ of $E$ over $G$ which is further $N(T)$-equivariant.
Question 1: do these properties determine $s$ up to a global phase factor?
If we let $\nabla$ denote the unique flat connection on $E$ which makes the actual determinant function parallel (i.e. covariantly constant) everywhere, then if we require that the section $s$ be covariantly constant with respect to $\nabla$, then we recover the determinant function uniquely up to a global phase factor, and the symmetry properties under $N(T)$ are automatically satisfied.
What remains to be done, is to describe this flat connection $\nabla$ on $E$ in a way that does not involve the determinant function, so as to avoid circularity.
What we know about $\nabla$ is that it is a flat connection on the trivial $U(1)$ bundle $E$ over $G = U(n)$, such that there exists a global parallel section $s$, unique up to a global phase factor, which is equivariant under $N(T)$.
Question 2: how can $\nabla$ be the defined directly (say using Maurer-Cartan 1-forms and geometric things like that)?
Edit: The whole point of my post, is to be able to define the determinant function on $U(n)$, simply as a parallel section (parallel with respect to the connection $\nabla$) which has the value 1 at the identity.
