How to prove that a strictly increasing function $f:[a, b]\rightarrow \mathbb{R}$ which has the intermediate value property is continuous on $[a, b]$.
Asaf Karagila
  • 393,674
Let $c$ be a point with $a<c<b$, and suppose given a small $\epsilon > 0$ (small enough that $c+\epsilon<d$ and otherwise arbitrarily small). Use the intermediate value property (and strict increasingness of $f$) to pick $d$ with $c<d<b$ for which $f(d)=f(c)+\epsilon.$ Since $f$ is strictly increasing, for all $x$ in $[c,d]$ we have $$f(c) \le f(x) \le f(d).$$ And $f(d)-f(c)=\epsilon.$ [Note: In the $\epsilon, \delta$ continuity definition, we have chosen $\epsilon$ first, and then found the point $d$, and are defining $\delta=d-c$.] This given "half" of continuity at $c$, and the left half is similar to show.
At either endpoint $a$ or $b$ we only need the above argument one way.
coffeemath
  • 29,884
  • 52
We have infact, more general result:
$f: \mathbb R \to \mathbb R$ strictly increasing and has IVP is continuous in $\mathbb R$.
Pf: If possible $f$ be not continuous in $\mathbb R$. So, there exists $c \in \mathbb R$ where $f$ is not continuous. So, there exists $\epsilon >0 ,\forall \delta>0$ with $|x-c|<\delta$ implies $|f(x)-f(c)|\ge \epsilon.$------(1).
Now as $f$ is strictly increasing $f(c-\delta)<f(c)$, Without loss of genarilty we may assume $l:=f(c-\delta)<f(c-\epsilon)$, Take a point $y_0 \in [f(c-\epsilon),f(c))$, for this $y_0$ there is $x_0\in [c-\delta,c)$ such that $f(x_0)=y_0$[IVP]. This contradicts (1)
Hint: Since $f$ is increasing, for every $c\in[a,b]$, $f(c^{\pm}):=\lim_{x\to c^\pm}f(x)$ exists, and it suffices to show that $f(c)=f(c^\pm)$, where for $c$=$a$(resp. $b$), only consider $c^+$(resp. $c^-$). If it is not the case, you may use the intermediate value property to derive a contradiction.
23rd
  • 16,234
  • 44
  • 70
You cannot prove that because it is not true, there are functions that are not continuous that have this property. Just think of a function that is strictly increasing but with discontinuities and that is defined in the hole interval that you will notice that it can still obey the property.Example of increasing funtion that abbeys the intermediate value property and that is not continuous.
  • The example you give doesn't satisfy the intermediate value theorem, as not all values of $f$ are not attainable in $[a,b]$. A better counter example is on the domain $[0,2]$ with the function $$f(x)=\begin{cases}x&0\leq x<1\2x&1\leq x\leq 2\end{cases}$$. – Daryl Nov 08 '12 at 19:57
    @Daryl Your function does not satisfy the IVP; since it takes the values $0$ and $2$, but not the value $1.5$. There is no counterexample ... – David Mitra Nov 08 '12 at 20:04
  • @DavidMitra I just realised I made a mistake when you replied. The second function should be $2(x-1)$ on $1\leq x\leq 2$. This maps every value from $[1,2]$ onto the range $[0,2]$. You can then choose an arbitrary function, satisfyiny the increasing property on $[0,1)$ and the piecewise function will satisfy the IVT. – Daryl Nov 08 '12 at 20:08
  • But since $g(x)=2(x-1)$ already covers $[0,2]$ and is strictly increasing there, the limit as $x \to 1^-$ of the first function must be $0$ in order to maintain that the piecewise function is strictly increasing and continuous. And (I think) that makes the function continuous at 1. – coffeemath Nov 09 '12 at 02:57
