In my head integration by parts has always been kind of vague and I just apply it without understanding whats really going on I guess. I.e. if I have the following:
$$\int_{u}^\infty (\ln x - \ln u) \mathrm dF(x) = \int_{u}^\infty \frac{1-F(x)}{x}\mathrm dx$$
I don't know how to handel it. For one I can't deal with the $\mathrm dF(x)$... I know it's like the "change in $F(x)$" and it's the "same" as $f(x)\mathrm dx$ so I write out the left had side like:
$$\int_{u}^\infty (\ln x - \ln u) \ f(x)\mathrm dx$$
and try to do integration by parts like:
$$u=(\ln x -\ln u) \qquad v= 1-F(x)$$
$$u'= \frac{1}{x} \qquad v'= f(x)$$
and then use the IBP formula to get the right hand side, but, for example, I don't really know "why" $v$ is $1-F(x)$ aside from maybe that the range of integration goes from $u$ to $\infty$, so like $ 1-F(x)$ would be $\operatorname{Pr}(X>u)$ sort of. It's all very loosely held together in my head and I usually get by in an exam since I'm fairly certain the answer is right but if I had to explain it, it kind of falls apart. Sort of the hazard of learning by mostly doing dozens of past papers I guess.
Can anyone fill the gaps. I'd appreciate multiple answers if possible (I tend to learn from what multiple sources say and have in common).
