How do you compare $6-2\sqrt{3}$ and $3\sqrt{2}-2$? (no calculator)
Look simple but I have tried many ways and fail miserably. Both are positive, so we cannot find which one is bigger than $0$ and the other smaller than $0$. Taking the first minus the second in order to see the result positive or negative get me no where (perhaps I am too dense to see through).
miracle173
  • 11,049
  • sorry, multiply both sides by $6+2\sqrt{3}$ and use $(a-b)(a+b)=a^2-b^2$ – luka5z Jun 10 '17 at 19:00
  • \begin{eqnarray} \sqrt{a}+ \sqrt{b}= \sqrt{a+b+2 \sqrt{ab}} \end{eqnarray} might be helpful. – Donald Splutterwit Jun 10 '17 at 19:01
  • @Learner132 A lot of the solutions here add or subtract from both sides then square then compare to infer about the direction of the original identity. This is only guaranteed to work if both values are positive before squaring. E.g. consider the counterexample: $2.5>1 \rightarrow 2.5-2>1-2 \rightarrow 0.5 > -1 \rightarrow 0.25 > 1$. – Ian Miller Jun 11 '17 at 11:49
  • I would just guesstimate. $\sqrt 3 \approx 1.75$, $\sqrt 2 \approx 1.4$, so $6 - 2 \sqrt 3 \approx 2.5$ and $-2 + 3 \sqrt 2 \approx 2.2$. – Robert Soupe Jun 15 '17 at 00:39
9 Answers9
20
$6-2\sqrt 3 \gtrless 3\sqrt 2-2$
Rearrange: $8 \gtrless 3\sqrt 2 + 2\sqrt 3$
Square: $64 \gtrless 30+12\sqrt 6$
Rearrange: $34 \gtrless 12\sqrt 6$
Square: $1156 \gtrless 864$
TonyK
  • 64,559
    You might simplify by $2$ before squaring… – Bernard Jun 10 '17 at 19:11
    Thank you, good answer, but I doubt if math teacher is okay with this (> or <) symbol – Learner132 Jun 10 '17 at 19:29
    What's important about any symbol is its mathematical meaning. If you can the mathematical meaning of this symbol to your math teacher, I'll bet he/she is open to its usage. – Lee Mosher Jun 10 '17 at 19:57
    You should probably mention that the squaring steps are valid (both forward and backward) since the values on both sides are clearly positive. – Rory Daulton Jun 11 '17 at 00:33
  • Yes, ordinarily you would start at the last step with a definite operator there (> in this case) and then work towards the inequality given to you. However, to find the necessary steps, it is often easier to work from what you’re given to something known, i.e., backwards. – BallpointBen Jun 11 '17 at 02:47
    I think its worth including $\iff$ symbols for each line with the accompanying justification as Rory Daulton says. – mrnovice Jun 11 '17 at 03:22
We have $\sqrt{3}\leq 1.8$ so $6-2\sqrt{3}\geq 2.4$, whereas $\sqrt{2}\leq 1.42$ so $3\sqrt{2}-2\leq 2.26$.
TomGrubb
  • 12,909
$$ 6-2√3 \sim 3√2-2\\ 8 \sim 3√2 +2√3 \\ 64 \sim 30+12√6\\ 34 \sim 12√6\\ 17 \sim 6√6\\ 289 \sim 36 \cdot 6\\ 289 > 216 $$
Brethlosze
  • 3,010
  • Thanks, quite understandable, but how I can explain ~ symbol to math teacher in this? – Learner132 Jun 10 '17 at 19:27
  • This $\sim$ simbol is a placeholder for an undefined relationship, you can use whatever other symbol you prefer, while you dont multiply by -1 – Brethlosze Jun 10 '17 at 19:29
  • I remember using that during school first courses without trouble – Brethlosze Jun 10 '17 at 19:29
  • I understand you. Well, I hope math teacher is okay with it although it is not covered in the lecture. – Learner132 Jun 10 '17 at 19:40
  • You could use a "?" sign also – Brethlosze Jun 10 '17 at 20:10
  • Or you could just write the proof backward, and then you could always use $>$... – Micah Jun 10 '17 at 20:36
  • Or you can put a $<$ and add any phrase including the words "by contradiction" hahhaha – Brethlosze Jun 10 '17 at 21:17
  • You don't show the above to the teacher. You start with $289 > 216$ and work your way up to $6-2√3 > 3√2-2$ – Steven Alexis Gregory Jun 11 '17 at 06:10
    Teachers know how this work and what you thought... rewritting everything is not needed. – Brethlosze Jun 11 '17 at 06:17
  • This is basically the same as TonyK's answer, and you posted almost simultaneously, so I don't know why he got all the votes... I agree that this is the sensible way to do it. I suppose some people may feel uncomfortable manipulating inequalities this way, but it seems very natural to me. I guess you could also write it with $<$ instead of $\sim$, and show that results in a contradiction. ;) – PM 2Ring Jun 14 '17 at 08:50
  • He replied after me actually, so then appeared above me. I am not jealous. Life goes on. Nothing bad is forever. I could be able to learn and live with that. – Brethlosze Jun 14 '17 at 10:23
Define
$a=6-2\sqrt 3>0$
$b=3\sqrt 2-2>0$
$a-b = 8 - (2\sqrt 3 + 3\sqrt 2)$
$(2\sqrt 3 + 3\sqrt 2)^2 = 30+12\sqrt 6 = 6×(5+2\sqrt 6) < 60 < 64$ because $6=2×3 < (5/2)^2$
$a-b > 8-8=0, a>b$
Oscar Lanzi
  • 39,403
Using simple continued fractions for $\sqrt {12}$ and $\sqrt {18}.$ Worth learning the general technique...Method described by Prof. Lubin at Continued fraction of $\sqrt{67} - 4$
$$ \sqrt { 12} = 3 + \frac{ \sqrt {12} - 3 }{ 1 } $$ $$ \frac{ 1 }{ \sqrt {12} - 3 } = \frac{ \sqrt {12} + 3 }{3 } = 2 + \frac{ \sqrt {12} - 3 }{3 } $$ $$ \frac{ 3 }{ \sqrt {12} - 3 } = \frac{ \sqrt {12} + 3 }{1 } = 6 + \frac{ \sqrt {12} - 3 }{1 } $$
Simple continued fraction tableau:
$$ \begin{array}{cccccccccc} & & 3 & & 2 & & 6 & \\ \\ \frac{ 0 }{ 1 } & \frac{ 1 }{ 0 } & & \frac{ 3 }{ 1 } & & \frac{ 7 }{ 2 } \\ \\ & 1 & & -3 & & 1 \end{array} $$
$$ \begin{array}{cccc} \frac{ 1 }{ 0 } & 1^2 - 12 \cdot 0^2 = 1 & \mbox{digit} & 3 \\ \frac{ 3 }{ 1 } & 3^2 - 12 \cdot 1^2 = -3 & \mbox{digit} & 2 \\ \frac{ 7 }{ 2 } & 7^2 - 12 \cdot 2^2 = 1 & \mbox{digit} & 6 \\ \end{array} $$
Continued fraction convergents alternate above and below the irrational number, we get $$ \frac{ 3 }{ 1 } < \sqrt {12} < \frac{ 7 }{ 2 } $$ Your first number was $6 - \sqrt {12},$ $$ 3 > 6 - \sqrt {12} > \frac{ 5 }{ 2 } $$ $$ \frac{ 5 }{ 2 } < 6 - \sqrt {12} < 3 $$
Next 18......................========================================
$$ \sqrt { 18} = 4 + \frac{ \sqrt {18} - 4 }{ 1 } $$ $$ \frac{ 1 }{ \sqrt {18} - 4 } = \frac{ \sqrt {18} + 4 }{2 } = 4 + \frac{ \sqrt {18} - 4 }{2 } $$ $$ \frac{ 2 }{ \sqrt {18} - 4 } = \frac{ \sqrt {18} + 4 }{1 } = 8 + \frac{ \sqrt {18} - 4 }{1 } $$
$$ \begin{array}{cccccccccc} & & 4 & & 4 & & 8 & \\ \\ \frac{ 0 }{ 1 } & \frac{ 1 }{ 0 } & & \frac{ 4 }{ 1 } & & \frac{ 17 }{ 4 } \\ \\ & 1 & & -2 & & 1 \end{array} $$
$$ \begin{array}{cccc} \frac{ 1 }{ 0 } & 1^2 - 18 \cdot 0^2 = 1 & \mbox{digit} & 4 \\ \frac{ 4 }{ 1 } & 4^2 - 18 \cdot 1^2 = -2 & \mbox{digit} & 4 \\ \frac{ 17 }{ 4 } & 17^2 - 18 \cdot 4^2 = 1 & \mbox{digit} & 8 \\ \end{array} $$
This time the number is $\sqrt {18} - 2.$
It is enough to use $$ 2 < \sqrt {18} - 2 < \frac{9}{4} $$
$$ \color{red}{ 2 < \sqrt {18} - 2 < \frac{9}{4} < \frac{ 5 }{ 2 } < 6 - \sqrt {12} < 3 } $$
Will Jagy
  • 139,541
In general we can solve problems like this with the following approach.
  1. Isolate a radical on one side of the ineqality.
  2. Check both sides of the inequality are positive. If one side is positive and the other is negative then you have your answer. If both sides are negative then multiply both sides by -1 and make a note of this since it means that the manipulated inequality will be the opposite of the un-manipulated one.
  3. Square both sides.
  4. Repeat until no radicals are left.
I'll use >=< to represent the unknown comparison.
$ 6-2\sqrt{3} >=< 3\sqrt{2}-2$
We start by adding 2 to both sides. This isolates one of the radicals.
$ 8-2\sqrt{3} >=< 3\sqrt{2}$
Both sides are clearly positive ( $ 2\sqrt{3} < 6 $ ) so we can square both sides without changing the comparison result.
In a more maginal case where we were unsure if the left hand side was positive we could have compared the two terms in the left hand side by squaring both of them and hence determined whether the left hand side was positive or negative.
$ 64 -32\sqrt{3} + 12 >=< 18$
Now lets collect terms.
$ 60 >=< 32\sqrt{3}$
Divide by four (not strictly needed but keeps the numbers smaller).
$ 15 >=< 8\sqrt{3}$
Square again.
$ 225 >=< 64 \times 3 $
$ 225 > 192 $
Therefore
$ 6-2\sqrt{3} > 3\sqrt{2}-2$
Peter Green
  • 1,256
Here's yet another way, for those who aren't comfortable with the $\gtrless$ or $\sim$ notation.
We can use crude rational approximations to $\sqrt 2$ and $\sqrt 3$.
$$\begin{align} \left(\frac{3}{2}\right)^2 = \frac{9}{4} & \gt 2\\ \frac{3}{2} & \gt \sqrt 2\\ \frac{9}{2} & \gt 3\sqrt 2 \end{align}$$
And $$\begin{align} \left(\frac{7}{4}\right)^2 = \frac{49}{16} & \gt 3\\ \frac{7}{4} & \gt \sqrt 3\\ \frac{7}{2} & \gt 2\sqrt 3 \end{align}$$
Adding those two approximations, we get $$\begin{align} \frac{9}{2} + \frac{7}{2} = 8 & \gt 3\sqrt 2 + 2\sqrt 3\\ 6 + 2 & \gt 3\sqrt 2 + 2\sqrt 3\\ 6 - 2\sqrt 3 & \gt 3\sqrt 2 - 2 \end{align}$$
PM 2Ring
  • 4,844
There is still some hope in taking the first minus the second in this case: $$6-2\sqrt{3} - (3\sqrt{2}-2) = 8 - (2\sqrt{3} + 3\sqrt{2})$$
So now the question boils down to if the expression with the square root exceeds $8$. We know that $8^{2} = 64$ and: $$(2\sqrt{3}+3\sqrt{2})^{2}=4*3+2(2\sqrt{3})(3\sqrt{2})+9*2 =30+12\sqrt{3}\sqrt{2}$$
Conversely: $$8^{2} = 64 = 28+36=28+6*6 = 28+6*\sqrt{6}\sqrt{6}$$
Subtracting them yields: $$ 28+6*\sqrt{6}\sqrt{6}-30+12\sqrt{3}\sqrt{2} = -2+6*\sqrt{6}\sqrt{6}-12\sqrt{3}\sqrt{2}$$
Thus this is only positive if the square root terms are positive and exceed 2. Comparing the square root terms: $$6*\sqrt{6}\sqrt{6}-12\sqrt{3}\sqrt{2} = 6*\sqrt{2}\sqrt{3}(\frac{\sqrt{2}}{\sqrt{2}})\sqrt{6}-12\sqrt{6}=12\frac{\sqrt{3}}{\sqrt{2}}\sqrt{6}-12\sqrt{6}=12\sqrt{6}(\frac{\sqrt{3}}{\sqrt{2}}-1)$$
We conclude that the square root term is positive since $\sqrt{3}>\sqrt{2}$ . But is it greater than $-2$? Or rather, how much do we need to multiply to the expression $\frac{\sqrt{3}}{\sqrt{2}}-1$ for it to be greater than $2$? $$n*(\frac{\sqrt{3}}{\sqrt{2}}-1)>2$$ $$n>\frac{2}{\frac{\sqrt{3}}{\sqrt{2}}-1}*\frac{\frac{\sqrt{3}}{\sqrt{2}}+1}{\frac{\sqrt{3}}{\sqrt{2}}+1}\approx\frac{2*(1.5+1)}{0.5} = 10$$ So the factor in front of the term $\frac{\sqrt{3}}{\sqrt{2}}-1$ should be at least 10. But since $12>10$ and $\sqrt{6}>1$, we conclude that $12\sqrt{6}>10$. Thus, substituting back to the original equation: $$-2+6*\sqrt{6}\sqrt{6}-12\sqrt{3}\sqrt{2} = -2+12\sqrt{6}(\frac{\sqrt{3}}{\sqrt{2}}-1) > 0$$ And so we conclude that: $$64>(2\sqrt{3}+3\sqrt{2})^{2}$$ and so, for positive root, $$8>(2\sqrt{3}+3\sqrt{2})$$ and $$ 8 - (2\sqrt{3} + 3\sqrt{2}) > 0 $$
You may use other approaches. Notice that I split $8^{2} = 28+36$. Equally viable is to split $8^{2} = 30+34$, and you might have to use a similar (Squaring than rooting) trick to show that $34 > 12\sqrt{6}$, and then finally conclude that $8>(2\sqrt{3} + 3\sqrt{2})$. This alternative approach should be able to give you a smaller threshold compared to the approximation I made midway.
NaOH
  • 111
$6-2√3 \approx2(1.732) = 6 - 3.464 = 2.536$
$3√2-2 \approx 3(1.414) - 2 = 4.242 - 2 = 2.242$
This implies that $\dfrac 52$ is between the two quantities:
\begin{align} \dfrac{49}{4} &> 12 \\ \dfrac 72 &> 2\sqrt 3 \\ \dfrac{12}{2} &> 2\sqrt 3 + \dfrac 52 \\ 6 - 2\sqrt 3 &> \dfrac 52 \end{align}
and
\begin{align} \dfrac{81}{4} &> 18 \\ \dfrac 92 &> 3\sqrt 2 \\ \dfrac 52 &> 3\sqrt 2 - 2 \end{align}
It follows that $6-2√3 > 3\sqrt 2 - 2$.
<<<<< added 11/23/2043 >>>>>
What I am looking for is a simple, improvable, method for finding nice bounds for $6-2√3$ and $3\sqrt 2 - 2$. First pass:
$$ \left( 2\sqrt 3 \right)^2 = 12 $$ $$ 9 < 12 < 16 $$ $$ 3^2 < \left( 2\sqrt 3 \right)^2 < 4^2 $$ $$ 3 < 2\sqrt 3 < 4 $$ $$ -4 < -2\sqrt 3 < -3 $$ $$ 2 < 6 - 2\sqrt 3 < 3$$
and
$$ \left( 3 \sqrt 2 \right)^2 = 18 $$ $$ 16 < 18 < 25 $$ $$ 4^2 < \left( 3 \sqrt 2 \right)^2 < 5^2 $$ $$ 4 < 3 \sqrt 2 < 5 $$ $$ 2 < 3 \sqrt 2 - 2 < 3 $$
And all we have accomplished is to show that both quantities are between 2 and 3. So we double the two quantities; that is, we compare $12-4√3 $ and $6√2-4$
$$ \left( 4\sqrt 3 \right)^2 = 48 $$ $$ 36 < 48 < 49 $$ $$ 6^2 < \left( 4 \sqrt 3 \right)^2 < 7^2 $$ $$ 6 < 4\sqrt 3 < 7 $$ $$ -7 < -4\sqrt 3 < -6 $$ $$ 5 < 12 - 4\sqrt 3 < 6 $$ $$ \dfrac 52 < 6 - 2\sqrt 3 < 3 $$
and
$$ \left( 6 \sqrt 2 \right)^2 = 72 $$ $$ 64 < 72 < 81 $$ $$ 8^2 < \left( 6 \sqrt 2 \right)^2 < 9^2 $$ $$ 8 < 6 \sqrt 2 < 9 $$ $$ 4 < 6 \sqrt 2 - 4 < 5 $$ $$ 2 < 3 \sqrt 2 - 2 < \dfrac 52 $$
And we conclude that
$$ 2 < 3 \sqrt 2 - 2 < \dfrac 52 < 6 - 2\sqrt 3 < 3 $$
  • see this answer same concept but better (less digits, can be easily verified by hand, using lower and upper bounds instead of $\approx$)) and 12 hours earlier than your answer – miracle173 Jun 11 '17 at 14:16
  • @miracle173 What you saw was only a part of what I intended to do. I needed some more time to think about the problem so I thought I had deleted everything. Obviously, I hadn't. What you see above is what I intended to do. – Steven Alexis Gregory Jun 11 '17 at 19:57
