The question is:
Show that the following defines an inner product on $\mathbb{R}^2$: $$ \langle ( x_1 , y_1 ) , ( x_2 , y_2) \rangle = x_1 y_1 + 2 x_1 y_2 + 2 x_2 y_1 + 8 x_2 y_2 $$
Tried to show that $\langle ( x_2 , y_2) , ( x_1 , y_1) \rangle$ is the same thing but came at a roadblock (it isn't).
It's a past exam, and the solution says that the inner product is defined by $X_1^T A X_2$ where $$ A = \begin{pmatrix} 1&2\\2&8 \end{pmatrix} $$
The exam is in two days, so any help would be greatly appreciated.
HINT: You have to show, for arbitrary $x,y,z$
$\langle x,y \rangle = \langle y,x \rangle$
$\langle ax+by,z \rangle = a\langle x,z \rangle + b\langle y,z \rangle$
(linearity in the second component follows by symmetry)
$\langle x,x \rangle > 0$ if $x \neq 0$
The first two things is calculating and see if it works out. For the last thing, you have to show that the expression is always greater than zero for every non zero vector. Since you know you can rewrite the inner product as:
$$X_1^TAX_2$$
it suffices to show that $$X^TAX >0$$
which is the same thing as saying that $A$ is positive definite. For this, you can for example use this post:
Proving that a symmetric matrix is positive definite iff all eigenvalues are positive
(Or even more simple, write the expression as a square)
Hint:
Definition: $\langle\alpha,\beta\rangle$ is an inner product if:
  1. $\langle\alpha+\beta,\gamma\rangle=\langle\alpha,\gamma\rangle+\langle\beta,\gamma\rangle$
  2. $\langle c\alpha,\beta\rangle=c\langle\alpha,\beta\rangle$; where c is scalar.
  3. $\langle\alpha,\beta\rangle=\langle\beta,\alpha\rangle$
  4. $\langle\alpha,\alpha\rangle\gt0 ; \alpha\neq0$ So, if you prove that $\langle(x_1,y_1),(x_2,y_2)\rangle$ satisfies the 4 conditions of definotion, you've already proved that it's an inner product.
Bilinearity is easy, particularly if you use the matrix form.
For the final condition, consider $$ \langle(x,y),(x,y)\rangle=x^2+4xy+8y^2=x^2+4xy+4y^2+4y^2= (x+2y)^2+4y^2\ge0 $$ When is such an expression equal to $0$?
egreg
  • 238,574
$A$ is positive-definite (both eigenvalues are strictly positive) and symmetric.
Since it is symmetric: $\langle X_1,X_2\rangle_A = X_1^TA\,X_2 = (A\,X_1)^TX_2 = X_2^T(A\,X_1) = X_2^TA\,X_1 = \langle X_2,X_1\rangle_A$
Since it is positive-definite: $\langle X,X\rangle_A \geq 0$ (it is zero iff $X=0$)
Therefore $\langle X_1,X_2\rangle_A$ defines an inner product!
$\langle (x_1,y_1),(x_2,y_2)\rangle_A = x_1\,x_2 + 2\,x_1\,y_2 + 2\,y_1\,x_2 + 8\,y_1\,y_2$
Daniel Cunha
  • 1,735
