Suppose that $X$ and $K$ are metric spaces, and $K$ is compact, and the graph of $f:X\rightarrow K$ is a closed subset of $X\times K$. Prove that $f$ is continuous. Show that compactness of $K$ cannot be omitted from the hypothesis, even when X is compact.
My solution: i tried doing it by proving the continuity by sequential criterion and for this i start with a sequence $\{x_n\}_{n=0}^{\infty}$ converging to some $x\in X$. Then $S=\big(\bigcup\limits_{n=1}^{\infty} \{x_{n}\}\big)\cup \{x\}$ is compact subset of X and hence $S^*=\big(\bigcup\limits_{n=1}^{\infty} (x_{n},f(x_n))\big)\cup (x,f(x))$ is closed in $X\times K$ and since $(S\cup \{x\})\times K$ is compact hence $S^*$ is compact and hence have a convergent subsequence. i am not able to move forward. any type of help will be appreciated. Thanks in advance.
bunny
  • 868
  • Note that you need only that $K$ is compact. The metric structure does not matter. –  May 08 '17 at 08:38
  • yes you are right. that link solved my problem but can you please tell me how did you find that link this much early? – bunny May 08 '17 at 08:49
  • I searched closed graph theorem and wiki tells me that your question is really called closed graph theorem in topology. So I search "closed graph theorem topology" and then I get to that. –  May 08 '17 at 08:53
