I hope I have provided all the information necessary to make my question clear and understandable.
The following theorem is well known in elementary number theory
Theorem. The linear Diophantine equation $ax+by = c$ has a solution if and only if $\, d \vert c \,$ where $d = \text{gcd}(a,b)$. If $x_0$,$y_0$ is any particular solution of this equation, then all other solutions are given by
$$x = x_0 + \bigg(\frac{b}{d}\bigg)t$$ $$y = y_0 - \bigg(\frac{a}{d}\bigg)t$$
where $t$ is an arbitrary integer (bold emphasis added).
Question. How is the transition made from $t$ being an existential integer in the proof to it being an arbitrary integer at the end of the proof?
Proof. We begin with two solutions $(x_0,y_0)$ and $(x\prime, y\prime)$. Then starting with the equation
$$ax_0 + by_0 = c = ax\prime + b\prime$$
we have
$$r(x\prime - x_0) = s(y\prime - y_0)$$
where $r$ and $s$ are relatively prime integers from $a = dr$ and $b = ds$. Consequently, Euclid's Lemma allows us to deduce that $r \vert (y_0 - y\prime)$; or $y_0 - y\prime = rt$ for some integer $t$.
So now we have some integer $t$ such that
$$y_0 - y\prime = rt$$
Substituting, we obtain
$$x\prime - x_0 = st$$
We then have the formulas
$$x\prime = x_0 + st = x_0 + \bigg(\frac{b}{d}\bigg)t$$ $$y\prime = y_0 + rt = y_0 - \bigg(\frac{a}{d}\bigg)$$
But then we show that the integer $t$ has no restrictions as to its values, because
$$\begin{align} ax\prime+by\prime &= a\bigg[x_0+\bigg(\frac{b}{d}\bigg)t\bigg] + b \bigg[y_0 - \bigg(\frac{a}{d}\bigg)t\bigg] \\ &= a(x_0+by_0) + \bigg(\frac{ab}{d} - \frac{ab}{d}\bigg)t \\ &= c + 0 \cdot t \\ &= c \end{align} $$
There are an infinite number of solutions of the given equation, one for each value of $t$
$\blacksquare$
I'm confused as to how $t$ can become arbitrary when it is existential. How do we extend the quantifier from existence to universality?
