For the function $f(x)$, find the constant n where $f(x)$ has a maximum at $(n,1)$$$f(x)=\frac{x^{n-x}}{(n-x)!}$$ It is roughly $0.561459...$, but this is through numerical guess and check work. I'm fairly confident that the solution will be some infinite series that involves the Euler-Mascheroni constant and the digamma function, along with the Reimann-Zeta function, but I haven't been able to work anything out that leads to any kind of evidence to suggest it even has a way to express $n$ as anything more than a numerical value.
Some of you may be wondering how I know that it can even have a maximum at $(n,1)$. you'll notice that when $n=x$, $f(x)=1$ and I'm not sure how to describe this so just play with the value of $n$ on https://www.desmos.com/calculator/jb8x3n0cya and you'll see how the graph works. The values that intercept with $y=1$ are what I've found to be important.
P.S. Should $f(x)$ be $f(x,n)$? I'm really not sure.
