Is it wrong to say that 100 is solution of $\sqrt x +10=0$?
I know that range of $\sqrt{x}$ is $[0, \infty)$ by convention. This convention is because of definition of a function. So if I consider $\sqrt x+10=0$ as a simple equation then can I say hundred is a solution to the equation?
I think I can say that because if I square both sides I get $x=100$ and also if I consider $\sqrt x+10=0$ just as a equation then there is no need of thinking about functions and the convention of omitting negative roots.
