The following theorem is due to Laplace:
Theorem: Suppose that $h$ is a real-valued $C^2$-function defined on the interval $(a,b) \subset \mathbb{R}$. If $h$ has a unique maximum at $c$ with $a<c<b$ so that $h'(c)=0$ and $h''(0)<0$, then, $$ \int _{a}^{b} e^{\lambda h(t)} \mathrm{d}{t} \sim e^{\lambda h(c)} \left( \frac{-2\pi}{\lambda h''(c)} \right)^{\frac{1}{2}} $$ as $\lambda \to \infty$.
Question: Is there any similar result for the case when $\lambda \to 0$?
