How to find an approximation for value of $2^x$ without using calculator?
For example, $2^{4.3}$.
Consider this: $$ 2^x \approx \dfrac{2^{\lfloor x \rfloor} + 2^{\lceil x \rceil}}{2} = 2^{\lfloor x \rfloor - 1} + 2^{\lceil x \rceil - 1} = 2^{\lfloor x \rfloor - 1} \cdot ( 1 + 2 ) = 3 \cdot 2^{\lfloor x \rfloor - 1}. $$ So the exponent is reduced by one, e.g. $$ 2^{4.3} \approx 3 \cdot 2^3 = 24$$ Of course this trick aims to deal with decimal exponents.
use taylor approximation , for instance
$2^{4.3} $
use integer part $a=4$ and fraction part $b=0.3$
now let us consider taylor approximation because, you have such kind of equation
$2^{a+b} $ which is the same as $f(x+\alpha)$ if $f(x)=2^x$
$$f(x) \approx f(a) + f'(a)(x-a)$$
derivative of $2^x=2^x\log(2)$
so we would have
$2^{4.3}=2^4+2^4*log(2)*(4.3-4)$
"'Point six nine three one" "That's the natural log of two." "What did you think it was?" page 12: https://books.google.com/books?id=8UJi7TTZ6UgC&pg=PA7&lpg=PA7&dq=heinlein+natural+log&source=bl&ots=S-tO0mqg4U&sig=oXlJvhgiuGQSkUnlf-xUOv6nzTA&hl=en&sa=X&ved=0ahUKEwiK24Kz2pXTAhUGTCYKHXO6C38Q6AEIHDAA#v=onepage&q=heinlein%20natural%20log&f=false:
– Ethan Bolker Apr 08 '17 at 20:58I suppose you are asking how to do it without a calculator or logarithm tables with a high precision. And how to do it fast. Of course, there is a way. Nowadays we calculate even indefinite integrals with computers. Well, here is what I suggest in this particular case:
$$2^{4.3}=2^3\cdot2^{1.3}=8\cdot2^{1.3}$$ Now it is very easy to get a very precise answer fast by using the Taylor's formula for fraction powers of the binomial (1+x):
$$(1+x)^{t}=1+\frac{t}{1!}\,x+\frac{t\,(t-1)}{2!}\,x^2+...+\frac{t\,(t-1)\cdot...\cdot t\,(t-n+1)}{n!}\,x^n+...$$
So, we get this:
$$2^{1.3}=(1+1)^{1.3}=1+\frac{1.3}{1!}\cdot1+\frac{1.3\cdot(1.3-1)}{2!}\cdot1^2+\frac{1.3\cdot(1.3-1)\,(1.3-2)}{3!}\cdot1^3+...$$
or
$$1+\frac{1.3}{1!}+\frac{1.3\cdot(1.3-1)}{2!}+\frac{1.3\cdot(1.3-1)\,(1.3-2)}{3!}+\frac{1.3\cdot(1.3-1)\,(1.3-2)\,(1.3-3)}{4!}...$$
For simplicity of my crude calculations I'm multiplying everything by $1000$:
$$1000+1300+\frac{130\cdot(13-10)}{2!}+\frac{13\cdot(13-10)\,(13-20)}{3!}+\frac{1.3\cdot(13-10)\,(13-20)\,(13-30)}{4!}...$$
Now we get this: $2300+195-13\cdot49/6+1.3\cdot49\cdot27/24≈2495-650/6+1.3\cdot2\cdot27≈2500-110+70=2460$
Now $\;8\cdot2460/1000=19680/1000=19.68\quad$ The actual number is 19.698... My calculation here is too crude but you get the idea. I don't even bothered with precise arithmetic here.
As the factorial in the denominator grows larger you get your precision. Note how the terms alternate (you either add a term or subtract it). I chose the number $1.3$ on a hunch to sorta "make" a few terms smallish.
I think it is important to understand the ideas, rather than memorize things like this: $$\sqrt[3]{1+x}=1+\frac{1}{3}\,x-\frac{2}{2!\cdot3^2}\,x^2+\frac{2\cdot5}{3!\cdot3^3}\, x^3-\frac{2\cdot5\cdot8}{4!\cdot3^4}\, x^4+...$$
PS: You can also calculate sines, cosines, logarithms etc. in a similar fashion that is "on paper" without logarithm tables or calculators.
Memorize a few trick. $2^{10} = 1024\approx 10^3$ so $2^{3.3} \approx 10$.
So $2^{k + \frac i/3} = 2^{k-3i + i*3.3}= 2^{k-3i}10^i$ so $2^{4.3} = 2^{1 + 3.3} = 20$ ish.
If you are happy to quote, without refernce to a calculator, that the approximate value of $\sqrt{2}$ is $1.4$ then, $$2^{4.3}=2^4\times2^{0.3}=16\times(\sqrt{2})^{0.6}\simeq16\times(1.4)^{0.6}$$ Now use the Binomial Theorem and get $$2^{4.3}\simeq 16\times(1+0.4\times0.6)=16\times1.24=19.84$$
This has an error of approximately 3%.
