Your answer is close but the factor of $2^{n - 1} - 1$ is not correct. (As an aside, your sum as written can be simplified using the same methods as below.)
Let $i = |A_1 \cap A_2|$. We would like to find the number of ways to construct $A_1$ and $A_2$ for each integer $1 \le i \le n - 1$ (note that if $i = n$, then $A_1 = A_2$, so there does not exist any two such distinct subsets). There are $\binom{n}{i}$ ways to choose $i$ common elements for $A_1$ and $A_2$. For each of the $n - i$ remaining elements of $A$, there are three places we can place each element: $A_1$, $A_2$, or neither. Since we cannot place all elements in neither set (otherwise $A_1 = A_2$), there are $\frac{1}{2}(3^{n - i} - 1)$ ways to place the remaining elements, where the factor of $1/2$ comes from the fact that we do not care about the order of $A_1$ and $A_2$. Therefore, there are $\binom{n}{i} \cdot \frac{1}{2} (3^{n - i} - 1)$ ways to select $A_1$ and $A_2$ given $i$, so the desired sum is
\begin{align}
S &= \sum_{i = 1}^{n - 1} i \cdot \binom{n}{i} \cdot \frac{1}{2}\left(3^{n - i} - 1 \right) \\
&= \sum_{i = 1}^{n} i \cdot \binom{n}{i} \cdot \frac{1}{2}\left(3^{n - i} - 1 \right) \\
&= \frac{1}{2} \sum_{i = 1}^{n} i \binom{n}{i} 3^{n - i} - \frac{1}{2} \sum_{i = 1}^{n} i \binom{n}{i}.
\end{align}
We now make use of the following identities (for a proof sketch, see here for example):
\sum_{i = 1}^{n} i \binom{n}{i} 3^{n - i} = n 4^{n - 1}; \qquad \sum_{i = 1}^{n} i \binom{n}{i} = n 2^{n - 1}.
Therefore,
\begin{align}
S &= \frac{1}{2} \cdot n 4^{n - 1} - \frac{1}{2} \cdot n 2^{n - 1} \\
&= \frac{n}{2} \left(4^{n - 1} - 2^{n - 1} \right) = n\left(2^{2n - 3} - 2^{n - 2} \right).
\end{align}
