If I got two independent random variables $A \sim R(0,1)$ and $B \sim R(0,1)$ and I have to calculate $E(max(A, B))$ wouldn't that then just be to pick one of them since they are equal in size? So it would be the same $E(A)$?
What would E(max{A,B}) be?
To compute $E(max(A, B))$, I'd start by computing $P(max(A, B) \le x)$. As Alain Chau has observed, $P(max(A, B) \le x) = P(A \le x) P(B \le x)$ since $A$ and $B$ are independent.
Since $A$ and $B$ are uniformly distributed on $[0, 1]$, you have $P(max(A, B) \le x) = x^2$ for $0 \le x \le 1$.
Finally, use the well-known formula $\int_0^\infty P(X > x) \: dx = E(X)$, which applies for non-negative random variables $X$ (this question may be relevant).
Michael Lugo
  • 22,354
To aid your intuition, consider the expected value of a fair die versus the expected value of rolling two dice and taking their maximum; it should be clear that their expected values are not the same. Mathematically, you can get around the max function by observing that $$P(\max(A,B)\leq x) = P(A \leq x)\cdot P(B\leq x) $$ since $$\max(A,B) \leq x \iff A \leq x \text{ and } B\leq x$$ and A and B are independent.
Alain
  • 935
Let $\epsilon>0$ and let $E$ denote the event that $A+\epsilon\leq B$.
Then: $$(A+\epsilon)1_E\leq\max(A,B)1_E$$ and consequently: $$\mathbb EA1_{E}+\epsilon\Pr(E)\leq\mathbb E\max(A,B)1_E$$
Taking $\epsilon>0$ small enough we get $\Pr(E)>0$ so that:
$$\mathbb EA1_E<\mathbb EA1_{E}+\epsilon\Pr(E)$$
That leads to:
$$\mathbb EA=\mathbb EA1_E+\mathbb EA1_{E^c}<E\max(A,B)1_E+E\max(A,B)1_{E^c}=\mathbb E\max(A,B)$$
addendum (hint for finding $\mathbb E\max(A,B)$)
$$\int_0^1\int_0^1\max(x,y)dxdy=\int_0^1\int_0^y\max(x,y)dxdy+\int_0^1\int_y^1\max(x,y)dxdy=$$$$\int_0^1\int_0^yydxdy+\int_0^1\int_y^1xdxdy$$
drhab
  • 151,093
