$\mathbb{Q}\cap [0,1]$ is not closed since any irrational numbers in $(0,1)$ is a limit point but not in $\mathbb{Q}\cap [0,1]$.
By Heine-Borel theorem, $\mathbb{Q}\cap [0,1]$ is not compact.
Now, instead of using Heine-Borel theorem, i want to use the definition of compact set to prove $\mathbb{Q}\cap [0,1]$ is not compat, i.e. find a sequence that converges to an irrational number $\in [0,1]$, example $\frac{1}{\sqrt{2}}$ and hence every subsquence converges to that irrational number as well.
I will appreciate if you prove the sequence converges to its limit instead of just stating it.
