Note: I know next to nothing about mathematical logic, so please don't feel that you have to explain any answer rigorously or technically in order for me to accept it.
Question: Is metric (Cauchy) completeness "outside the realm" of first order logic?
In particular, is the Dedekind-Cantor axiom necessarily a statement of second order logic?
Background: This is a follow-up to my previous question and my attempt to answer that question.
Tarski proved at least two interesting theorems which seem to suggest that first order logic is "unable to distinguish" between (some) metrically complete spaces and metrically incomplete spaces. For example, he showed that any real closed field is elementarily equivalent to the real numbers (which are metrically complete), including the real algebraic numbers (which are not metrically complete). He also proved the Lefschetz principle, which (I think) states something like all algebraically closed fields of characteristic zero are elementarily equivalent.
As I said before, I know next to nothing about mathematical logic, to the extent that I don't really know or understand the difference between first and second order logic, except that it maybe has something to do with what sets quantifiers are allowed to range over.
In particular, I do not understand the reason why the distinction between the two should be particularly interesting. However, if one type is unable to make a distinction, between Cauchy incomplete and Cauchy complete metric spaces, that is important to analysis, then I would begin to understand somewhat on a naive level the importance of the distinction. Hence this question.
Note: I hope this question doesn't seem too stupid because I "should" know that the answer is "yes" because of the elementary equivalence of all real closed fields. Consider the answers to this (very) related question. One answer to that question would imply that the answer to my question is "yes", because it says "a structure with the first order properties of the real numbers may not satisfy the completeness axiom, which is not first order". However, another answer to that question (actually two other answers) to that question point out that ZFC can be formulated in first order logic by something called the Lowenheim-Skolem theorem, and since analysis (including metric completeness) can be formulated in terms of ZFC, which is first order, the answer to my question should be "no". Obviously there is a subtle point that I am completely oblivious to here, hence my confusion and uncertainty. Any patience you may have for my naivete would be greatly appreciated.
