I tried to solve this question but it turns into a 4th degree equation and I could only get one solution for this equation,i.e., 2. It is to be evaluated for solutions. Thanks.
Arnaldo
  • 21,342
We have $$x^2 +\frac {x^2}{(x-1)^2} =8$$ $$\Rightarrow x^2(x^2-2x+2) = 8 (x^2-2x+1) $$ $$\Rightarrow x^4-2x^3-6x^2+16x-8 =0$$ $$\Rightarrow (x-2)(x^3-6x+4)=0$$ $$\Rightarrow (x-2)(x-2)(x^2+2x-2)=0$$
Hope you can take it from here by using the quadratic formula to factor the last bit.
Note that multiplying $(x-1)^2$ on each side gives us that
$$x^2(x-1)^2+x^2=8(x-1)^2$$
Note that this is $$x^2(x-1)^2+x^2+(x-1)^2=9(x-1)^2$$ However, note that this implies $$(x^2-x+1)^2=9(x-1)^2$$ As seen here. So $$x^2-x+1= \pm 3(x-1)$$ I think you can continue from here.
S.C.B.
  • 22,768
writing your equation in the form $$x^2+\left(\frac{x}{x-1}\right)^2-8=0$$ and factorizing we obtain $$\left( {x}^{2}+2\,x-2 \right) \left( x-2 \right) ^{2}=0$$ can you finish now? p.s.: it must be $$x\ne 1$$
$$x^2 +\frac{x^2}{(x-1)^2} = 8$$ $$x^2 +\frac{x^2}{(x^2-2x + 1)} = 8$$ $$x^2 = (8 - x^2)(x^2-2x + 1)$$ $$x^2 = (8 - x^2)x^2-(8 - x^2)2x + (8 - x^2)$$ $$x^2 = 8x^2 - x^4 -16x + 2x^3 - x^2 + 8$$ $$0 = - x^4 -16x + 2x^3 + 6x^2 + 8 $$ $$(x-2)^2(x^2+2x-2)= 0$$ $$x= 2$$ $$x= \sqrt{3}-1 $$ $$x= -1 - \sqrt{3}$$
