I need to solve an equation relating to investment for a particular variable. Wolfram alpha failed to solve it due to computation time. Mathematica gives up after about ten seconds. Perhaps I am typing in something incorrectly. The variable i is not in the complex number system.
Here is what the equation looks like in prettyPrint on wolfram alpha. (Give it about 10 seconds to print to the screen). Tiny Url isn't permitted. This link is too long to display normally with an easy click so you'll have to copy it. Don't just click on the link it will be the wrong problem.
$$\frac{(i+1) \left(\frac{r+1}{i+1}-1\right) \left(\frac{r+1}{i+1}\right)^p}{(r+1) \left(\left(\frac{r+1}{i+1}\right)^p-1\right)}=z$$
https://www.wolframalpha.com/input/?i=solve+for+r,+(((1%2B((1%2Br)%2F(1%2Bi)-1))%5Ep((1%2Br)%2F(1%2Bi)-1))%2F(((1%2B((1%2Br)%2F(1%2Bi)-1))((1%2B((1%2Br)%2F((1%2Bi))-1))%5Ep-1)))%3Dz
This is what I type into mathematica. It errors out after a while and says that the system cannot be solved with the methods available to Solve. Is anyone aware of a different function to use?
Solve[((1 + ((1 + r)/(1 + j) - 1))^
p*((1 + r)/(1 + j) -
1))/(((1 + ((1 + r)/(1 + j) -
1))*((1 + ((1 + r)/((1 + j)) - 1))^p - 1))) == z, r]
I have no desire to solve this by hand unless there is some trick.
