Indeed, my question is very similar to Is the right-hand derivative equal to the right-hand limit of the derivative?, but with different conditions (there is no assumption about the differentiability).
The hypothesis is: $\lim_{x \to a^+}f'(x)=f'_+(a)$ if the expresions on both of the sides exist. (where $f'_+(a)=\lim_{h \to 0^+} \frac{f(a+h)-f(a)}{h}$)
I have seen it in my analysis book but am not able to give a rigorous proof. So far, I have tried to use the definitions to derive $|\lim_{x \to a^+}f'(x)-f'_+(x)|<\epsilon$ for all $\epsilon>0$, but with no result. Does anyone know a better way?
My another hypothesis is that if $\lim_{x \to a^+}f'(x)$ exists and $f$ is continuous at $a$ then the above mentioned equality holds.
May I ask you for help?
