This problem is a case of Power Group Enumeration in the sense of
the paper by Fripertinger which was discussed quite extensively at the
following MSE link.
The set of values consists of the possible edges and is being permuted
by the rotations of the hexagon, call this $G$. Edges are represented
by products $A_p A_q$ where $p$ and $q$ range from zero to eleven and
correspond to a clockwise enumeration of the exits and there are no
edges between adjacent exits (same edge). This is a feature of the
problem which is open to debate and which I hope I have interpreted
correctly. The slots are simply six slots being permuted by the
symmetric group $S_6.$ The technique is exactly the same as at the
quoted link -- note that we seek sets of edges and not multisets which
simplifies things considerably. In a nutshell we consider pairs
$(\beta,\alpha)$ of permutations from the edge permutations $G$ and
the symmetric group $S_6$ and compute the generating function that
corresponding to all possible ways of covering $\alpha$ with cycles
from $\beta.$ At the end we extract those terms that contain every
exit exactly once. A remarkable feature of this problem is that we are
working with generating functions here but the generating function
that appears when we try to cover $a_1^6$ with cycles (fixed points)
from $a_1^{60}$ produces a completely unmanageable number of terms
which it is impossible to process. Fortunately the contribution of
this term can be computed in closed form. It has no symmetries and
simply counts all tiles before symmetry. As we must exclude edges
between adjacent exits we get by inclusion-exclusion
$$\bbox[5px,border:2px solid #00A000]{
\sum_{k=0}^6 {6\choose k} (-1)^k \frac{(12-2k)!}{2^{6-k} (6-k)!}
= 6040.}$$
We simply wire this value into the program and detect $a_1^{60}$
during the Power Group Enumeration computation. This is all we
need to be aware of at this time and the answer is
$$\bbox[5px,border:2px solid #00A000]{1060.}$$
The reader is invited to verify this result by classifying tiles
according to their symmetries and counting the number of tiles in
every class.
I also verfied this by a total enumeration routine which in fact does
not require all that much time / space and confirms the above
findings. PGE obviously generalizes while simple enumeration does not.
This was the Maple code.
with(combinat);
pet_autom2cyclesA :=
proc(src, aut)
local numa, numsubs, marks, pos, cycs,
data, item, cpos, clen;
numsubs := [seq(src[k]=k, k=1..nops(src))];
numa := subs(numsubs, aut);
marks := Array([seq(true, pos=1..nops(aut))]);
cycs := []; pos := 1; data := [];
while pos <= nops(aut) do
if marks[pos] then
clen := 0; item := []; cpos := pos;
while marks[cpos] do
marks[cpos] := false;
item := [op(item), aut[cpos]];
cpos := numa[cpos];
clen := clen+1;
od;
cycs := [op(cycs), clen];
data := [op(data), item];
fi;
pos := pos+1;
od;
return [data, mul(a[cycs[k]], k=1..nops(cycs))];
end;
pet_cycleind_symm :=
proc(n)
local p, s;
option remember;
if n=0 then return 1; fi;
expand(1/n*add(a[l]*pet_cycleind_symm(n-l), l=1..n));
end;
edges_all_src :=
proc()
option remember;
local edges;
edges :=
add(add(A[p]*A[q], q=p+1..11), p=0..11)
- add(A[2*p]*A[2*p+1], p=0..5);
[seq(p, p in edges)];
end;
pet_perms_edge_cind :=
proc()
option remember;
local cind, p, q, perm, sl,
edges, edgeperm, rotind;
edges := edges_all_src();
cind := [];
for rotind from 0 to 5 do
sl :=
[seq(A[p]=A[(p+2*rotind) mod 12], p=0..11)];
edgeperm := subs(sl, edges);
cind :=
[op(cind), pet_autom2cyclesA(edges, edgeperm)];
od;
cind;
end;
tiles :=
proc()
option remember;
local slot_idx, edge_idx, gf, var, flat, cycs,
edge_term, slot_term, contrib, cover, deg, onesize;
slot_idx := pet_cycleind_symm(6);
edge_idx := pet_perms_edge_cind();
gf := 0;
for slot_term in slot_idx do
for edge_term in edge_idx do
if edge_term[2] = a[1]^60 then
next;
fi;
if type(edge_term[2]/slot_term,
`monomial`) then
contrib := 1;
for var in indets(slot_term) do
cycs :=
select(c->nops(c)=op(1,var),
edge_term[1]);
onesize := 0;
deg := degree(slot_term, var);
for cover in choose(cycs, deg) do
onesize := onesize
+ deg!*op(1,var)^deg*
mul(mul(el, el in cyc),
cyc in cover);
od;
contrib := contrib*onesize;
od;
gf := gf + lcoeff(slot_term)*contrib;
fi;
od;
od;
gf := expand(gf);
for var from 0 to 11 do
gf := coeff(gf, A[var], 1);
od;
(gf + 6040)/6;
end;
enum_all_symm :=
proc()
option remember;
local recurse, count, edges, orbits;
orbits := table();
recurse :=
proc(sofar, sel, n, pos)
local orbit, sl, rotind;
if n = 6 then
count := count + 1;
orbit := {};
sl :=
[seq(A[p]=A[p+2*rotind mod 12],
p=0..11)];
orbit :=
{op(orbit), subs(sl, sel)};
od;
orbits[orbit] := 1;
return;
fi;
if pos > nops(edges) then
return;
fi;
recurse(sofar, sel, n, pos+1);
if nops(indets(sofar*edges[pos])) =
2*(n+1) then
recurse(sofar*edges[pos],
{op(sel), edges[pos]},
n+1, pos+1);
fi;
end;
count := 0;
recurse(1, {}, 0, 1);
[count, nops([indices(orbits)])];
end;
Addendum Mon Jun 26 2017. Presenting a completely reworked
algorithm and implementation, which gives an instant answer. The
previous version computed the entire generating function in the
variables representing the exits, expanding intermediate terms even
including those that did not contribute. As indicated this algorithm
breaks down when placing cycles corresponding to $a_1^{60}$ on
$a_1^6.$ The new version uses
$$[z^k] \prod_{q\in C} (1+zq)$$
to represent a choice of $k$ cycles from a set of cycles $C$ and does
not expand this term, which means that the contribution from
$a_1^{60}$ only consists of $60$ terms as opposed to ${60\choose 6},$
which is not feasible. We thus get a product of these (times a leading
coefficient) when there exists a covering of the slot permutation
$\alpha$ by cycles from the edge permutation $\beta,$ where $k$ is the
number of cycles of a given size in $\alpha$ and $C$ are the cycles of
that size from $\beta,$ which is not a conjugacy class in this problem
but an actual permutation of the edges. Having constructed this
product we differentiate with respect to all variables in sequence and
set them to zero thereafter, which isolates the contribution from
those terms where each exit occurs just once. We extract the
coefficients that correspond to the desired power of $[z^k]$ at the
very end, producing a number which gives the possible coverings of
$\alpha$ by cycles from $\beta$ that contribute to the count of
admissible tiles. The Maple code was as follows (the enumeration
routine has also been improved.) We omit the prefix that is shared
with the first version.
tiles :=
proc()
option remember;
local slot_idx, edge_idx, slot_term, edge_term,
cycs, deg, gf, var, res;
res := 0;
`monomial`) then
gf := 1;
cycs :=
edge_term[1]);
gf := gf*deg!*op(1, var)^deg
*mul(1+z[op(1, var)]*mul(el, el in cyc),
cyc in cycs);
od;
gf :=
subs(A[var] = 0, diff(gf, A[var]));
od;
gf :=
coeftayl(gf, z[op(1, var)]=0,
degree(slot_term, var));
od;
res := res + lcoeff(slot_term)*gf;
fi;
od;
od;
res/nops(edge_idx);
end;
enum_all_tiles :=
proc()
option remember;
local recurse, count, edges, orbits, sl;
orbits := table();
sl :=
[seq([seq(A[p]=A[p+2*r mod 12], p=0..11)],
r=1..5)];
recurse :=
local orbit, rotind;
if n = 6 then
count := count + 1;
orbit := [sel];
for rotind to 5 do
orbit :=
[op(orbit),
subs(sl[rotind], sel)];
od;
orbits[sort(orbit)[1]] := 1;
return;
fi;
return;
fi;
2*(n+1) then
n+1, pos+1);
fi;
end;
count := 0;
[count, numelems(orbits)];
end;
Addendum Wed Jun 28 2017. We present the case of arbitrary
polygonal tiles having $q$ sides rather than hexagonal ones to
complete this discussion and end on a challenge to the reader. We get
by inclusion-exclusion for the count with no symmetries the formula
\sum_{k=0}^q {q\choose k} (-1)^k \frac{(2q-2k)!}{2^{q-k} (q-k)!}.}$$
Here we choose the $k$ spots where there is an edge between adjacent
exits (which we are wanting to avoid), for a factor of ${q\choose k}.$
This leaves $2q-2k$ exits. We choose two of these to connect by an
edge, then another two from the remaining exits, and another two, and
so on, for a multinomial coefficient ${2q-2k\choose 2,2,\ldots,2}.$
Here we may choose one set of edges in $(q-k)!$ ways, hence the
formula. We obtain the sequence starting at $q=1$:
$$0, 2, 8, 60, 544, 6040, 79008, 1190672, 20314880, 387099936,\ldots$$
Taking symmetries into account yields the following sequence:
$$0, 2, 4, 22, 112, 1060, 11292, 149448, 2257288, 38720728\ldots$$
and the challenge to the reader is of course to compute more
terms for the latter. This is the Maple code:
edges_all_src :=
proc(q)
option remember;
local edges;
edges :=
add(add(A[p]*A[r], r=p+1..2*q-1), p=0..2*q-1)
- add(A[2*p]*A[2*p+1], p=0..q-1);
end;
proc(q)
option remember;
local cind, perm, sl,
edges := edges_all_src(q);
cind := [];
for rotind from 0 to q-1 do
sl :=
[seq(A[p]=A[(p+2*rotind) mod 2*q], p=0..2*q-1)];
cind :=
od;
cind;
end;
tiles :=
proc(q)
option remember;
slot_idx := `if`(q=1, [a[1]], pet_cycleind_symm(q));
edge_idx := pet_perms_edge_cind(q);
res := 0;
`monomial`) then
gf := 1;
cycs :=
edge_term[1]);
cyc in cycs);
od;
for var from 0 to 2*q-1 do
gf :=
od;
gf :=
od;
fi;
od;
od;
res/nops(edge_idx);
end;
tiles_all :=
q -> add(binomial(q,k)*(-1)^k*(2*q-2*k)!/2^(q-k)/(q-k)!,
k = 0..q);
enum_tiles_all :=
proc(q)
option remember;
orbits := table();
sl :=
[seq([seq(A[p]=A[p+2*r mod 2*q], p=0..2*q-1)],
r=1..q-1)];
recurse :=
if n = q then
count := count + 1;
orbit := [sel];
for rotind to q-1 do
orbit :=
[op(orbit),
od;
return;
fi;
return;
fi;
2*(n+1) then
n+1, pos+1);
fi;
end;
count := 0;
end;
Addendum Fri Jun 30 2017. The data for dihedral symmetries being
taken into account (rotational and reflectional) are as follows:
$$0, 2, 4, 19, 80, 638, 6054, 76692, 1137284, 19405244,\ldots $$
Addendum Mon Jul 3 2017. It appears that plain Burnside is still
the best approach. This requires that we compute the number of tiles
fixed by each of the $q$ rotations including the identity, which fixes
all tiles. These are counted by the inclusion-exclusion formula given
above. For the remaining rotations we have that they must be constant
on the cycles (obtained by factorizing the corresponding permutation
of edges). This means that to be fixed by a given rotation a cycle of
edges is either switched on or off (all edges simultaneously). We use
a backtracking search to determine which cycles may be switched on at
the same time without creating conflict (more than one edge incident
on the same exit.) This lets us calculate three more values for
rotational symmetries and we obtain
$$0, 2, 4, 22, 112, 1060, 11292, 149448, 2257288, 38720728,
\\ 740754220, 15648468804, 361711410384, \ldots$$
We also find that we have effectively solved the problem for tiles
whose number of sides is a prime. We find (more of these can be
computed)
$$2, 4, 112, 11292, 740754220, 361711410384, 222595582448849152,
\\ 258327454310582805036, 661821993709898403923269564,
\\ 10266982973657640119698928948136690256,\ldots$$
The Maple code for this goes as follows.
with(combinat);
proc(src, aut)
if marks[pos] then
cpos := numa[cpos];
clen := clen+1;
od;
fi;
pos := pos+1;
od;
end;
edges_all_src :=
proc(q)
option remember;
local edges;
edges :=
end;
tiles_no_symm :=
*(2*q-2*k)!/2^(q-k)/(q-k)!, k=0..q);
bs_tiles :=
proc(q)
option remember;
local res, sl, recurse, edgecycs, cind, vsets,
edges, edgeperm, rotind, seen, factored;
res := tiles_no_symm(q);
recurse :=
proc(cycs, sofar, pos)
local data, nxt;
if nops(sofar) = 2*q then
return 1
fi;
if pos > nops(cycs) then
return 0
fi;
data := recurse(cycs, sofar, pos+1);
if nops(cycs[pos] intersect sofar) = 0 then
data := data +
recurse(cycs, cycs[pos] union sofar, pos+1);
fi;
return data;
end;
cind := [];
seen := table();
sl :=
cind :=
[op(cind),
od;
for factored in cind do
if not(type(seen[factored[2]], `integer`)) then
vsets :=
map(indets,
select(cf -> { seq(degree(cf, v), v in indets(cf)) }
= { 1 },
map(cyc -> mul(el, el in cyc), factored[1])));
seen[factored[2]] := recurse(vsets, {}, 1);
fi;
res := res + seen[factored[2]];
od;
res/q;
end;
With Burnside we also get three more terms for dihedral symmetry,
which yields
$$ 0, 2, 4, 19, 80, 638, 6054, 76692, 1137284, 19405244,
\\ 370597430, 7825459362, 180862277352,\ldots$$
The reason why the above code for cyclic symmetry is structured the
way it is becomes apparent when we study the code for dihedral
symmetry, which is why I decided to present it here, omitting
duplicate code.
edges_all_src :=
proc(q)
option remember;
local edges;
edges :=
add(add(C[p]*C[r], r=p+1..2*q-1), p=0..2*q-1)
- add(C[2*p]*C[2*p+1], p=0..q-1);
subs([seq(C[2*p]=A[p], p=0..q-1),
seq(C[2*p+1]=B[p], p=0..q-1)],
[seq(p, p in edges)]);
end;
tiles_no_symm :=
bs_tiles_dh :=
proc(q)
local res, sl, recurse, cind, vsets,
recurse :=
local data, nxt;
return 1
fi;
return 0
fi;
data := data +
fi;
return data;
end;
cind := [];
seen := table();
if rotind >= 1 then
sl :=
[seq(A[p]=A[(p+rotind) mod q], p=0..q-1),
seq(B[p]=B[(p+rotind) mod q], p=0..q-1)];
cind :=
[op(cind),
fi;
sl :=
[seq(A[p]=B[q-1-((p+rotind) mod q)], p=0..q-1),
seq(B[p]=A[q-1-((p+rotind) mod q)], p=0..q-1)];
cind :=
[op(cind),
od;
vsets :=
map(indets,
= { 1 },
fi;
od;
res/q/2;
end;
