Let $R$ be a abelian group under a binary operation denoted by + and let its identity element be denoted by $0$ . If we define multiplication by $ab= 0$, for all $ a, b \in R$, then $R$ becomes a ring.
Is there any other way of defining multiplication on $R$ so that $R$ becomes a ring?
RKR
  • 547
    Have a look: http://math.stackexchange.com/questions/102761/define-two-differents-vector-space-structures-over-a-field-on-an-abelian-group?rq=1 – Domates Jan 10 '17 at 16:07
  • @Aweygan A ring need not to be a vector space. – Crostul Jan 10 '17 at 16:11
  • @Awaygan & Ergul - yes! I made a mistake. I actually wanted to ask a question about rings, which I have posted now. – RKR Jan 10 '17 at 16:12
    Check this answer: http://math.stackexchange.com/a/93412/133781 – Xam Jan 10 '17 at 16:41
For some choices of $R$ there are no other multiplications on $R$, even if you require that they satisfy no axioms besides distributing over addition. For instance, consider $R=\mathbb{Q}/\mathbb{Z}$ and suppose you have a product on $R$ that distributes over addition. Let $x,y\in\mathbb{Q}/\mathbb{Z}$ be arbitrary; say $x$ is represented by a rational number $\frac{a}{b}$ and $y$ is represented by a rational number $\frac{c}{d}$ (with $a,b,c,d\in\mathbb{Z}$). Let $x'$ be the element of $\mathbb{Q}/\mathbb{Z}$ represented by $\frac{a}{bd}$. Then $dx'=x$ (where $dx'$ just means a sum of $d$ copies of $x'$), so since our product distributes over addition we have $$xy=(dx')y=d(x'y)=x'(dy).$$ But $dy$ is represented by the rational number $d\frac{b}{d}=b$ which is an integer, so $dy=0$. Thus $xy=x'\cdot 0=0$.
(More generally, a similar argument applies to any abelian group $R$ which is divisible but in which every element has finite order.)
Eric Wofsey
  • 330,363
