Apologies if this has been asked before, since it seems rather simple. I enjoy messing around with formal mathematics, and I once derived the following formula which holds for many functions (see my question here; no-one has yet responded to my request for criteria describing for which $q(x)$ it holds):
$$\sum_{n=0}^{\infty}q(n)=\int_{0}^{\infty}q(s)ds-\sum_{k=1}^{\infty}\frac{B_{k}q^{[k-1]}(0)}{k!}\tag{*}$$
where $B_n$ are the Bernoulli numbers. Using this formula with $q(x)=\frac{x}{e^x-1}$ and the identities $\int_0^\infty \frac{x^{s-1}}{e^x-1}=\Gamma(s)\zeta(s)$ and $\frac{x}{e^x-1}=\sum\limits_{n=0}^\infty \frac{B_n}{n!}x^n$, it was easy to show (since $\lim\limits_{n\rightarrow\infty}{\frac{n}{e^n-1}}=0$) that:
$$\sum_{n=1}^\infty \frac{n}{e^n-1}=\frac{\pi^2}{6}-1-\sum_{n=0}^\infty \frac{B_n B_{n+1}}{n!(n+1)!}$$
But the odd Bernoulli numbers are zero past $n=3$ so that we get:
$$\sum_{n=1}^\infty \frac{n}{e^n-1}=\frac{\pi^2}{6}-\frac{11}{24}\tag{1}$$
Now this is very accurate indeed; Wolfram Alpha declares the error to be on the order of $10^{-16}$. Further, using $(*)$ for $q(x)=\frac{x^{2m+1}}{e^x-1}$ in a similar manner gives:
$$\sum_{n=1}^\infty \frac{n^{2m+1}}{e^n-1}=\Gamma(2m+2)\zeta(2m+2)-\sum_{n=0}^\infty \frac{B_n B_{2m+n+1}}{n!(2m+n+1)!}$$
which simplifies to:
$$\sum_{n=1}^\infty \frac{n^{2m+1}}{e^n-1}=(2m+1)!\zeta(2m+2)+\frac{B_{2m+2}}{2(2m+2)!}\tag{2}$$
For $m=1$ this gives:
$$\sum_{n=1}^\infty \frac{n^3}{e^n-1}=\frac{\pi^4}{15}-\frac{1}{1440}$$
which Wolfram Alpha declares to have an error on the order of $10^{-3}$. The $m=2$ case appears to also have an error on the order of $10^{-3}$.
If we use $q(x)=\frac{bx}{e^{bx}-1}$ in $(*)$ and then set $b=\ln{a}$ then I think we get the following purported identity:
$$\sum_{n=1}^\infty \frac{n}{a^n-1}=\frac{\pi^2}{6(\ln{a})^2}-\frac{1}{2\ln{a}}+\frac{1}{24}\tag{3}$$
The accuracy of $(3)$ appears extremely good; e.g. for $a=2$ it is $10^{-16}$, for $a=3$ it is $10^{-15}$, and for $a=6$ it is still $10^{-9}$. All of this makes me believe that these formula are not exactly correct, but their accuracy amazes me. I don't know if what's going on in this question has any relevance here.
My questions are: Can anyone confirm that all of the highlighted expressions are in fact only approximations, or are some of them actually correct? What in general are the error terms for $(2)$ and $(3)$? Can anyone explain why these expressions are in fact so accurate?
