$$x^{x^{x^{.^{.^{.}}}}} = 8$$
Then how to solve for x?
I first tried like this
$x^8=8$ but I don't get any way to solve.
Fawad
  • 2,034
Notice that
$$x^8=8\\\implies x=\sqrt[8]8\approx1.29683955465$$
And since
$$e^{-e}<x<e^{e^{-1}}$$
then it converges to the proposed number.
It then remains that none of the other solutions to $x^8=8$ are possible, which is explained in this answer.
There is no way to obtain an analytical solution in terms of elementary functions.
However, one can find an expression in terms of the Lambert W function. This expression evaluates to $8=-\frac{W(-ln(x))}{ln(x)}$. This expression can be solved using numerical methods.
However, as noted by others you may notice that infinite tetration (technical word for power-tower) of $x$ converges if and only if $x \in [e^{-e},e^{1/e}]$. Therefore, your may use your positive real solution to $x$ for $x^8=8$. This will be identical to the solution to your question since: $$e^{-e}<x<e^{1/e}$$ Therefore, $x$ cannot converge to any other value.
