We have these equations over real numbers : $$ x^2 = 2^x $$ and $$ e^x = \ln x$$
First of all , we need number of solutions using algebraic ways and then find value of x individually in these equations .
Please Help!
S.H.W
  • 4,379
For your first equation, the real solutions are $x=2$, $x=4$ and $x = -\frac{2}{\ln(2)} W(\ln(2)/2)$, where $W$ is the Lambert W function.
Your second equation has no real solutions.
EDIT: The Lambert W solution comes about in the following way.
Write the equation as $$ x^2 = e^{x \ln(2)} $$
Letting $x = - \dfrac{2 w}{\ln(2)}$, this becomes $$ \dfrac{4 w^2}{\ln(2)^2} = e^{-2w} $$ i.e. $$ w e^w = \pm \frac{\ln(2)}{2}$$
Now by definition the solutions of $w e^w = c$ are $w = W(c)$ where $W$ is a branch of the Lambert W function. The real solutions are given by the "$0$" or principal branch if $c \ge -1/e$ and the "$-1$" branch if $-1/e \le c < 0$.
Now $-1/e < -\ln(2)/2 < 0$, so there we have both branches, but this happens to be one of the places where $W$ has "closed-form" values: $W_0( -\ln(2)/2) = -\ln(2)$ and $W_{-1}( -\ln(2)/2) = -2 \ln(2)$, corresponding to the equations $$\eqalign{(-\ln(2)) e^{-\ln(2)} &= - \frac{\ln(2)}{2}\cr (-2 \ln(2)) e^{-2 \ln(2)} &= -\frac{\ln(2)}{2}\cr}$$ This is where the $x=2$ and $x=4$ solutions come from.
$+\ln(2)/2 > 0$, so here we have one real solution, $w = W_0(\ln(2)/2)$ (which we write as just $W(\ln(2)/2)$), and so $x = \frac{-2}{\ln(2)} W(\ln(2)/2)$.
Robert Israel
  • 448,999
  • How you got it ? I need complete way and not try to guess solutions! – S.H.W Dec 13 '16 at 16:19
  • I don't think @Robert Israel deserves a very dry answer with a ? and a !. He has given you the three exact solutions. Usually, the third (non integer) root of this rather classical equation is given in an approximate manner, by a convergent sequence; see for instance (http://mathforum.org/library/drmath/view/54607.html). – Jean Marie Dec 13 '16 at 16:37
  • Duplicate of (http://math.stackexchange.com/q/56325) – Jean Marie Dec 13 '16 at 16:38
  • @JeanMarie Can you explain how we can find number of real roots using Lambert function ? – S.H.W Dec 13 '16 at 16:54
  • There is a single root that uses $W$ for its description. Its approximate value can be obtained through Wolfram Alpha. – Jean Marie Dec 13 '16 at 16:58
  • Yes! Wolfram Alpha is very good source but I can't use it in exams ! I want to find a way for counting number of solutions . – S.H.W Dec 13 '16 at 17:02
  • The point (whether you want to use $W$ or not to express the solutions) is that if $f(x) = x e^x$, $f(x) = y$ has no real solutions if $y < -1/e$, one (namely $x=-1$) if $y = -1/e$, two if $-1/e < y < 0$, and one if $y \ge 0$. This can be seen from the properties of the graph of $f$. – Robert Israel Dec 16 '16 at 20:23
