I need to find a multiple of $5$ call it $5k$ with the following properties:
  1. $5k \equiv 3 $ mod $6$
  2. $5k \equiv 2 $ mod $7$
My first instinct is to start with the Chinese Remainder Theorem, but I do not know how to start. Could I get a few hints? Please explain the modular arithmetic manipulations needed to solve this problem.
    The inverse of $5$ mod $6$ is $5$, so want $k\equiv 15\pmod{6}$. So want $k\equiv 3\pmod{6}$. The inverse of $5$ mod $7$ is $3$, so want $k\equiv 6\pmod{7}$. Now it is a standard CRT problem. But the numbers are so small that applying CRT machinery is overkill. From $k\equiv 6\pmod{7}$, the candidates are $k=6,13,20,27, 34$. Which one of these satisifies $k\equiv 3\pmod{6}$? – André Nicolas Sep 23 '12 at 04:55
To make the computations easy to understand, we first consider general equations.
Let $a,b,n$ be integers. Suppose gcd$(a, n) = 1$. Consider the following equation.
$ax \equiv b$ (mod $n$)
Since gcd$(a, n) = 1$, we can solve $ay \equiv 1$ (mod $n$) by Euclid's algorithm. Then $x = by$ (mod $n$) is the solution.
Let $a,b,n,m$ be integers. Suppose gcd$(n, m) = 1$. Consider the following equatiuons.
$x \equiv a$ (mod $n$)
$x \equiv b$ (mod $m$)
Since gcd$(n, m) = 1$, we can find, by Euclid's algorithm, integers $k, l$ such that
$mk \equiv 1$ (mod $n$)
$nl \equiv 1$ (mod $m$)
Then $x = amk + bnl$ (mod $nm$) is the solution.
Now let's solve the given equations
$5k \equiv 3$ (mod $6$)
$5k \equiv 2$ (mod $7$)
We get(by Euclid's algorithm or just by testing)
$k \equiv 3$ (mod $6$)
$k \equiv 6$ (mod $7$)
Then we can apply the above method to find $k$. Since
$7 \equiv 1$ (mod $6$)
$-6 \equiv 1$ (mod $7$)
$k = 3\cdot7 -6\cdot6 = -15 \equiv 27$ (mod $42$)
Makoto Kato
  • 42,602
  • Could you explain where you get $k \equiv 3\mod 6$ and $k \equiv 6\mod7$? I do not understand all the operations of congruences. Once you get those equations and the $7 \equiv 1\mod6$ and $-6 \equiv 1\mod7$ I see how you employ the Chinese remainder theorem. – CodeKingPlusPlus Sep 23 '12 at 14:36
  • @CodeKingPlusPlus By Euclid's algorithm or by testing. I added some explanations in my answer. – Makoto Kato Sep 23 '12 at 19:11
  • I see now how to get those congruences you found, but now I do not remember how I understood your reasoning for $k = -15$ and how $7 \equiv 1\mod6$ and $-6 \equiv 1\mod7$ justify this. – CodeKingPlusPlus Sep 23 '12 at 20:15
  • @CodeKingPlusPlus Just apply the method to solve $x \equiv a$ (mod $n$), $x \equiv b$ (mod $m$). – Makoto Kato Sep 23 '12 at 20:24
  • What is "the method"? – CodeKingPlusPlus Sep 23 '12 at 20:47
  • @CodeKingPlusPlus I wrote the method in my answer from the line 5 to the line 11. – Makoto Kato Sep 23 '12 at 20:50
  • I am trying to really understand this. I see in the first part that $ax \equiv b\mod n$ then if we can write $ay \equiv 1\mod n$ then our solution is $x = by$. However, I do not see how this fact plays a role in solving our problem. It appears to me that our coefficient $a$ is $5$ and we never set up an equation of the form $5y \equiv 1\mod n$. – CodeKingPlusPlus Sep 23 '12 at 22:29
  • @CodeKingPlusPlus Do you understand how to solve $ax \equiv b$ (mod $n$)? – Makoto Kato Sep 23 '12 at 23:05
  • I think I see it now. If you plugin $amk$ for $x$ into $x \equiv a\mod n$ then you satisfy the congruence. Where $mk \equiv 1\mod n$ – CodeKingPlusPlus Sep 23 '12 at 23:10
  • @CodeKingPlusPlus First solve $ay \equiv 1$ (mod $n$) by Euclid's algorithm. Then $x = by$ (mod $n$) is the solution of $ax \equiv b$ (mod $n$). – Makoto Kato Sep 23 '12 at 23:18
Hint $\ $ By Easy CRT, $\rm\:mod\ 42\!:\ 5k\, \equiv\, 2+7\,(1/7\ mod\ 6)\, \equiv\, 9\ \Rightarrow\ k \,\equiv\, 3\cdot 3/5 \,\equiv\, 3\cdot 45/5\,\equiv\, 27$
Bill Dubuque
  • 272,048
  • Is Easy CRT always a viable solution to these linear congruences? – CodeKingPlusPlus Sep 23 '12 at 14:34
  • @Code Yes, Easy CRT is simply the general Chinese Remainder Theorem packaged in a form easy to apply. To apply CRT you have two choices, either first scale both equations by $1/5$ then apply CRT to solve for $\rm,k,$ (as in other answers); alternatively, as I did, apply CRT to solve for $\rm,x = 5k,:$ then, scale the solution by $1/5$ to get $\rm,k.$ It doesn't matter what order you do the steps of CRT and scaling by $1/5$. – Bill Dubuque Sep 23 '12 at 15:53
  • when you write $\frac{1}{5}$ do you mean 5 inverse?($5^{-1}$). And to calculate $5$ inverse do you perform the following: $gcd(a, b) = 1 = a\cdot r + b\cdot s$ – CodeKingPlusPlus Sep 23 '12 at 22:32
  • @Code $\ $ If $\rm:(a,m) = 1:$ then $\rm:1/ a = a^{-1}:$ exists mod m, so $\rm:ax \equiv b:$ has the unique solution $\rm: x \equiv a^{-1} b = b/a.:$ You can compute inverses using the extended Euclidean algorithm, but for small numbers various tricks often are quicker, e.g. as above $\rm,mod\ 42!:\ 3\equiv 45:\Rightarrow:3/5\equiv 45/5 \equiv 9,:$ hence $\rm:k \equiv 9/5 \equiv 3\cdot 3/5\equiv 3\cdot 9 \equiv 27.$ – Bill Dubuque Sep 23 '12 at 22:35
Let x = 5k. Solve x = 3(mod 6) and x = 2(mod 7) simultaneously. You get x = 9(mod 42). Therefore
5k = 9(mod 42)
5k = 135(mod 42)
k = 27(mod 42)
