Let $f: \mathbb{R} \rightarrow \mathbb{R}$ be a continuous function such that: $$f(x+y) = f(x) + f(y)$$ $$f(1) = 1$$ Show that $$f(x) = x$$ I have been having trouble approaching this problem. I have shown, through a system of equations, that $f(x+y) = x + y$, but that's about as far as I can get. Appreciate any help anyone has to offer!
1prove it for $x$ of the form $\frac1n$ first, then for all rationals. Prove $f(n)=n$ for natural numbers $n$. – Mirko Nov 09 '16 at 01:14
3If you did prove $f(x+y)=x+y$ for $\forall x,y$ then it follows that $f(x)=x$ by just letting $y=0$. Maybe you should post your proof, though. – dxiv Nov 09 '16 at 01:16
See I need to find all functions $f:\mathbb R \rightarrow \mathbb R$ which are continuous and satisfy $f(x+y)=f(x)+f(y)$ (and the posts linked there) or I want to show that $f(x)=x.f(1)$ where $f:R\to R$ is additive (and the posts linked there). – Martin Sleziak Nov 09 '16 at 06:03
See that
$$f(0)=f(0)+f(0)=2f(0)\implies f(0)=0$$
$$\begin{align}f(a+b+c+\dots+z) & =f(a)+f(b+c+\dots+z) \\&=f(a)+f(b)+ f(c+\dots+z)\\&=\dots\\&=f(a)+f(b)+f(c)+\dots+f(z)\end{align}$$
For natural numbers $x$, we have
$$f(x)=f(\underbrace{1+1+1+\dots+1}_x)=\underbrace{f(1)+f(1)+\dots+f(1)}_x=1+1+1+\dots+1=x$$
$$f(x)=x\ \forall\ x\in\mathbb N$$
For positive rational numbers,
$$1=f(1)=f(\underbrace{\frac1x+\frac1x+\frac1x+\dots+\frac1x}_x)=f(\frac1x)+f(\frac1x)+\dots+f(\frac1x)=xf(\frac1x)$$
$$1=xf(\frac1x)\implies f(\frac1x)=\frac1x\ \forall\ x\in\mathbb N$$
$$f(\frac yx)=f(\frac1x+\frac1x+\dots+\frac1x)=f(\frac1x)+f(\frac1x)+\dots+f(\frac1x)=yf(\frac1x)=\frac yx\\f(\frac yx)=\frac yx\ \forall\ (x,y)\in\mathbb N\times\mathbb N$$
$$f(x)=x\ \forall\ x\in\mathbb Q^+$$
For positive real numbers, every real number is the cauchy sequence of rational numbers, which, since $f(x)$ is continuous, gives us
$$f(x)=x\ \forall\ x\in\mathbb R^+$$
Finally, for all negative numbers, we have
$$0=f(0)=f(x-x)=f(x)+f(-x)$$
$$0=f(x)+f(-x)\implies f(-x)=-f(x)=-x$$
- 13,049
- 74,685
2The standard proof: First for integers, then for rationals, finally, by continuity, for reals. btw, weaker assumptions than continuity are sufficient, for example bounded in some interval. – marty cohen Nov 09 '16 at 03:33
@martycohen You honestly don't even need to prove for the integers TBH, as the rationals take care of that. I just put it in because it follows a good line of thinking. – Simply Beautiful Art Nov 09 '16 at 14:51
If we let $y = 1$: $$f(x + 1) = f(x) + 1$$ This is a recurrence relation and can be solved with simple techniques. However, we already know what the solution is supposed to be. Proving that $f(x) = x$ is a solution:
LS: $$f(x + 1) = x + 1$$
RS: $$f(x) + 1 = x + 1$$
Because LS = RS, $f(x) = x$ is a solution to our problem. Note that this does not prove that it's the only solution.
- 2,448
The reason this works is because $f(1)=1$. If you want to do this for $a$, you need to prove $f(a)=a$, which is the problem at hand. – Simply Beautiful Art Nov 09 '16 at 14:29
Oh, that is true. I suppose the above only works for integers. However, we also know that $f(ax) = af(x)$, which can extend it to rationals. – Kaynex Nov 09 '16 at 17:14
@Kaynex and at that point, you get my answer pretty much. – Simply Beautiful Art Nov 10 '16 at 19:03
