-1
$\displaystyle\sum_{i=0}^{k-1}2^i=2^k-1$ for all $k \in\Bbb N$.
Clearly, the first step here is easy. You can start with k=1 and solve to get $2^0=2^1-1$.
What is a bit more challenging is the induction step. I don't even know where to begin here. Where would I even begin?
StubbornAtom
  • 17,052
  • Hint: $\sum_{i=0}^{k} 2^i = 2^k + \sum_{i=0}^{k-1} 2^i$. Though, unless you have to use induction, it's a lot easier to just remember that $a^k - b^k = ...$ – dxiv Oct 11 '16 at 02:41
  • I would think you need to use it though, since basis step seems to follow the problem. – Aggrawal Puja Oct 11 '16 at 02:47
  • You must know the context better. In general, if the problem does not specifically say "prove *using induction* that...", it means that any proof is acceptable. – dxiv Oct 11 '16 at 02:49
  • The way the question is implied is that @AggrawalPuja is not comfortable with using sigma notation in an induction question. i.e. the question has asked him to use induction. – Hugh Entwistle Oct 11 '16 at 02:56
first prove that $\sum_{i=0}^{k}2^i = 2^{k+1}-1$
or equivalently $\sum_{i=0}^{k-1}2^i + 2^k= 2^k + 2^k - 1$
rtpax
  • 296
In the way your question is titled - you don't appear to be confident with sigma notation?
Sigma means "sum", so you may rephrase your question as a sum (i.e. physically write down the terms with ' ... ' to seperate the terms in between).
So $$\sum_{i=0}^{k-1} 2^i \text{ is equivalent to }2^0+2^1+2^2+\cdots2^{k-1} $$
Would this help you 'picture' the induction? It should be a very simple task! If you are not forced to use induction, simply observe that this is a geometric series, and immediately $$\sum_{i=0}^{k-1} 2^i = \frac{2^k-1}{2-1} = 2^k-1$$
For the induction itself:
BASE CASE: (you have already done this)
INDUCTIVE HYPOTHESIS: We assume that
$$\sum_{i=0}^{k-1}2^i=2^k-1$$
and now we wish to show that if the hypothesis is true, then it is also true for $k+1$
$$\text{RTP: } \sum_{i=0}^{k}2^i=2^{k+1}-1$$
$$ LHS = \sum_{i=0}^{k}2^i = \sum_{i=0}^{k-1}2^i + 2^k = (2^k -1) + 2^k =2^{k+1}-1=RHS$$
and so we can conclude that the statement is true by induction.
If you found this answer useful, please accept it so it doesn't show up as an 'unanswered' question
  • This makes sense, but you don't need to add k to any side or the like? is it just that simple? – Aggrawal Puja Oct 11 '16 at 03:00
  • @AggrawalPuja refer to my edit. This is the way to do it by induction - but it is a bit unnecessary for this particular formula. – Hugh Entwistle Oct 11 '16 at 03:17
  • Does RTP refer to right hand side? That makes much more sense, but I see you can also skip the steps as well. – Aggrawal Puja Oct 11 '16 at 03:21
  • RTP is short for "required to prove". RHS is short for "right hand side".
    The only skips I may have skipped is the more formal language, but I am not here to provide you with this - you need to be able to write the polished one for yourself.
    – Hugh Entwistle Oct 11 '16 at 03:23
You have stated a question, but are a bit ambiguous as to what your main concerns with the problem are. Is it the sigma that's confusing to you, or is it the induction? Nonetheless, let's try and clear those up.
Induction
Proof based on induction is a simple recursive proof that let's you extend a minimum of two cases to an infinite amount of cases. It merely requires your proof to be in terms of another case. This happens to be $n+1$ in most scenarios.
You start with a base case which you can rigorously show to be true. From there, you simply assume that a case, say $n$ is true, and then use that to show that the $n+1$ case is true.
Your Problem
For your particular problem, you have already identified the base case, $n = 1$.
From here, what you want to do is assume that $$\sum_{i=0}^{n} 2^{i} = 2^{n+1} - 1$$ (we call this the inductive hypothesis) and use that to prove that the $n+1$ case is true, or that $$\sum_{i=0}^{n+1} 2^{i} = 2^{n+2} - 1$$.
This may look daunting, but you can exploit the sigma here to rewrite $$\sum_{i=0}^{n+1} 2^{i} = \sum_{i=0}^{n} 2^{i} + 2^{n+1}$$ Now some of these terms should start looking familiar. Maybe one of them is our inductive hypothesis?
Try substituting in what we assumed to be true, and then make it look like $2^{n+2} - 1$. Best of luck.
