Prove that one can solve the congruence $cx \equiv b \pmod m \Longleftrightarrow \gcd(c,m)|b$. Show, moreover, that the answer is unique $\bmod{m/\gcd(c,m)}$
My Work
Proof of $(\Rightarrow)$:
Assume that $cx \equiv b \pmod m$ has a solution, call it $x_1$. Let $d = \gcd(c,m)$ Then \begin{align*} cx_1 \equiv b \pmod m &\Longleftrightarrow m | (cx_1 - b) \\ &\Longleftrightarrow cx_1 = km + b, \quad k \in \Bbb Z \\ &\Longleftrightarrow cx_1 + (-k)m = b \\ \end{align*} As the $\gcd$, $d$ divides all linear combinations of $c$ and $m$, so $d | b$.
Proof of $(\Leftarrow)$:
Assume $d | b$. Then $b = dn$ for some $n \in \Bbb Z$. As the $\gcd$, $d = cs + mt$ for some $s,t$. So \begin{align*} dn &= csn + mtn \\ b &= csn + mtn \\ csn - b &= (-tn)m \\ csn - b &\equiv 0 \pmod m\\ csn &\equiv b \pmod m \end{align*}
Taking $x = sn$, we have a solution to the linear congruence $cx \equiv b \pmod m$.
My Question
I am not sure how to prove uniqueness from here. Should I say that $cx \equiv b \pmod m$ gives that, for $d = \gcd(c,m)$, $$m | (cx -b ) \Longrightarrow \left({m \over d}\right) \mid \left({cx - b \over d}\right) = {c \over d}x - {b \over d}$$ However, I'm not sure how to move from here to uniqueness. I have that ${c \over d}x = {m\over d}k + {b\over d}$, but this doesn't seem to be much.
Bill Dubuque
  • 272,048
Moderat
  • 4,437
  • Lemma: $gx \equiv gy \pmod{gn}$ if and only if $x \equiv y \pmod n$. –  Sep 14 '12 at 23:27
Hint $ $ If $ \,x,y\,$ are solutions then $ \ cx\equiv b\equiv cy\pmod{\! m}\ $ so, defining $ \ d=(m,c)\,$ we have
$$ \,m\,|\,c\,(x\!-\!y) \iff \color{#0a0}{\frac{m}d}\,\bigg|\,\color{#0a0}{\frac{c}d}\,(x\!-\!y)\color{#C00}{\iff} \frac{m}d\,\bigg|\ x\!-y,\ \ {\rm by} \ \ \left(\color{#0a0}{\frac{m}d,\frac{c}d}\right)\color{#90f}{= \frac{(m,c)}d} = 1\qquad$$
Remark $\ $ The final $ $ '$\color{#C00}{\!\!\iff}\!\!$' $ $ employs $\rm\color{#0a0}{Euclid's\ Lemma}$ and the $\rm\color{#90f}{\rm distributive\ law}$ for GCDs.
Alternatively $\ $ Bezout yields: $ \, d = (c,m) = j\:\!c+k\:\!m,\,\ j,k\in\Bbb Z.\,$ Let $ \,z = x-y.\,$ Then
$\!\bmod m\!:\ \color{#0a0}{cz\equiv 0\equiv mz}\ \Rightarrow\ dz = (c,m)z = j\:\!\color{#0a0}{cz}+k\:\!\color{#0a0}{mz \equiv 0},\,$ so $ \ m\,|\,dz\,\Rightarrow\,m/d\,|\,z$
Intuitively see this answer for an approach using modular fractions.
Bill Dubuque
  • 272,048
You want to show that if $cx_1\equiv b\pmod m$ and $cx_2\equiv b\pmod m$, then $x_1\equiv x_2\pmod{m/d}$. Let $c'=c/d$ and $m'=m/d$. You’ve shown that $d\mid b$, so let $b\,'=b/d$.
You have $cx_1-b=k_1m$ and $cx_2-b=k_2m$ for some $k_1,d_2\in\Bbb Z$, so $c'x_1-b\,'=k_1m'$ and $c'x_2-b\,'=k_2m'$, and therefore $c'x_1\equiv b\,'\pmod {m'}$ and $c'x_2\equiv b\,'\pmod {m'}$. In particular, $c'x_1\equiv c'x_2\pmod{m'}$. Now use the fact that $c'$ and $m'$ are relatively prime to get the desired conclusion.
Brian M. Scott
  • 616,228
Suppose that $cx_1\equiv b\pmod{m}$ and $cx_2\equiv b\pmod{m}$. Then $$c(x_1-x_2)\equiv 0\pmod{m}.$$ Let $d=\gcd(c,m)$, and let $c=kd$ and $m=dn$. Then $kd(x_1-x_2)\equiv 0\pmod{dn}$, and therefore $k(x_1-x_2)\equiv 0\pmod{n}$.
Suppose that $c\ne 0$. Since $k$ and $n$ are relatively prime, $k$ has an inverse $l$ modulo $n$. Multiply through by $l$. We get $x_1-x_2\equiv 0\pmod{n}$, which is the desired result.
In the degenerate case $c=0$, we need to show that any two solutions of $(0)x\equiv 0\pmod{m}$ are congruent modulo $1$, which is clearly true.
André Nicolas
  • 507,029
