13
I have an equation with this shape, where $k,t_1,r \in \Bbb N$:
$$2^{(x+1)^2}=k+t_1(x^2+r)$$
And I noticed that I can find $t_1$ in terms of $x$ as follows:
$$ \frac{{\rm d} }{{\rm d}x} 2^{(x+1)^2} = \frac{{\rm d} }{{\rm d}x} \left( k+t_1(x^2+r) \right)$$
And then I would continue as follows:
$$ 2(x+1)\cdot2^{(x+1)^2}\cdot\ln(2) = t_12x$$
$$ (x+1)\cdot2^{(x+1)^2}\cdot\ln(2) = t_1x$$
So finally:
$$ t_1=\frac{(x+1)\cdot2^{(x+1)^2}\cdot\ln(2)}{x}$$
Is it possible to use a derivative in such case? I think that if both functions $2^{(x+1)^2}$ and $t_1(x^2+r)$ are equivalent and the derivative exists it might be possible, but I am not very sure about the validity of that step. Thank you!
iadvd
  • 8,875
    Well, $1-ke^x = 0$ at $0$ doesn't means $-ke^x=0$ (which is after the derivative). – Jacky Chong Oct 04 '16 at 00:38
    It seems to me that for most values of $x$, the formula you derived for $t_1$ will not be an integer, so it does not satisfy the conditions you set. What exactly is the first equation in the question about? Is it supposed to be true for all $x$ (that is, it is setting two functions of $x$ equal), or is it to be solved for $x$, that is, it is true for (possibly) one or two values of $x$? – David K Oct 04 '16 at 00:46
  • @DavidK probably the point you mention is the key. Initially the equation was intended for natural numbers, $n \in \Bbb N$ instead of $x \in \Bbb R$, but I thought it could be extended to rationals in this case without problem due to the shape of the functions. – iadvd Oct 04 '16 at 00:49
    @DavidK: The natural number thing is not a problem -- every natural number solution is a real solution, so you can solve the problem by finding all real solutions, and then figuring out which real solutions are natural number solutions. –  Oct 04 '16 at 07:20
    @Hurkyl The "natural number" concern is just a hint (apparently not a successful one) at a deeper concern, namely the simultaneous treatment of $t_1$ as a constant and as a non-constant function of $x$. – David K Oct 04 '16 at 13:18
  • @mrf thanks for the reference! imho, the answers of the present question are a little bit more developed, but the main points are in both questions. – iadvd Oct 04 '16 at 14:35
5 Answers5
28
This only applies if your equation is an identity, meaning it's true for all $x$.
This is why it makes sense to differentiate a Taylor series to find one for the derivative of a function.
However, it does not hold true for an equation that only holds true for some $x$. Example, you cannot differentiate $x^2 = 4$ to come up with $2x = 0$ and expect the solution to the latter to be the solution to the former.
Deepak
  • 26,801
  • Related: more information about what is an identity, equation and conditional equation: http://math.stackexchange.com/a/606800/189215 – iadvd Oct 05 '16 at 08:28
You have shown that starting from that equation (which holds where? in some interval I guess), you get an expression for $t_1.$ That looks absurd, doesn't it? We have the constant $t_1$ equal to a function of $x?$ Dubious to say the least.
What happened is that you assumed the equation holds in some interval. It doesn't. If you assume that a false assertion is true, then you can derive any weird conclusion you like. (I heard this story a while back: Bertrand Russell once told his philosophy students that assuming $0=1,$ you could prove anything. A student after class challenged him: "OK, assuming $0=1,$ prove that you are god." Russell: "OK, it follows that $1=2.$ Since god and I are two, it follows that we are one, therefore I am god." I hope that story is true.)
zhw.
  • 105,693
  • thanks for the feedback! I was really doubting about the step, that is why I asked about the possibility, but gathering all the answers I think that it will not be a good idea finally. It was too good because finding that $t_1$ in terms of $x$ was a very nice opportunity to simplify the variables in the original expression. – iadvd Oct 04 '16 at 01:07
Generally, when stating an equation with symbols such as $x$ or $r$, you need to be very specific about what you actually mean by this equation. For example, when we write $$ \sec^2 x = 1 + \tan^2 x \qquad \text{for }-\frac\pi2 < x < \frac\pi2 $$ we mean that the expression on either side of the equation is a function of $x$ over the entire open interval $\left(-\frac\pi2, \frac\pi2\right)$. In that case it is completely appropriate to differentiate both sides, because the equation asserts that the left and right sides are the exact same function of $x$ over some interval of the real number line, so we can take the derivative of this function with respect to $x$ (provided we are inside that interval and provided the derivative exists). Since it's the same function on either side of the equation, all you get when you differentiate both sides is the derivative of that function, which of course is equal to itself even if it happens to be written a little differently in one place than in the other.
On the other hand, if we assert that $r$ and $k$ are known constants and $x$ is unknown in $$ e^{rx} = kx^2 - 1, $$ we now have an equation that can be solved for $x$. This particular equation is true for either one or two distinct values of $x$ (depending on the values of $k$ and $r$); other equations may have three solutions, $17$ solutions, or no solutions. In the introduction of this equation, however, there was never any implication that $e^{rx}$ and $kx^2 - 1$ are the same function of $x$ over any open interval. Since they are not the same function of $x$, there is no reason to think that their derivatives will be equal, so taking the derivatives of both sides and setting them equal is not a legitimate thing to do.
In your question, you assert the equation $$2^{(x+1)^2}=k+t_1(x^2+r),$$ then propose to "find $t_1$ in terms of $x$". It is not 100% clear what the equation was supposed to mean, even after clarifications in several comments, but it seems likely that the equation was supposed to represent the idea that $k$, $t_1$, and $r$ are known constants and that $x$ is an unknown value for which you wish to solve. In that interpretation, you have something much like the example $e^{rx} = kx^2 - 1$ above, that is, you do not have the same function on two sides of an equation, and there is no justification for setting the derivatives of both sides equal.
But let's suppose for a moment that you did actually mean that the things on each side of the equation are the same function. This clearly cannot be true if $k$, $r$, and $t_1$ are all constants, but let's suppose that only $k$ and $r$ are given as constants. Then it does make sense to say, let's solve for $t_1$ in terms of $x$, provided that you mean that $t_1$ is a function of $x$ such that the entire right-hand side of the equation actually is the same function of $x$ as the left-hand side of the equation.
But if you make that interpretation, then the assertion $$ \frac{{\rm d} }{{\rm d}x}( k+t_1(x^2+r)) = t_1 \cdot 2x $$ is simply wrong, because your interpretation of the problem was that $t_1$ is a function of $x$, and therefore you cannot treat $t_1$ as a constant when differentiating $t_1(x^2+r)$. Instead, you need to apply the product rule. The fact that going down your path ends up setting $t_1$ equal to some non-constant function of $x$ indicates that it was not OK to ignore the derivative of $t_1$ itself with respect to $x$.
Of course, there is a much simpler way to solve for $t_1$ in terms of $x$, assuming $t_1$ is a function of $x$: just manipulate the original equation (without taking derivatives) to isolate $t_1$. Using standard techniques of high-school algebra to eliminate $k$ and then $x^2+r$ from the right-hand side of the equation, we get $$ \frac{2^{(x+1)^2} - k}{x^2+r}=t_1, $$ and that's $t_1$ expressed as a function of $x$ for any constants $k$ and $r$.
David K
  • 98,388
  • very good explanation, thanks again. My tests indeed support your indications. In this case the substitution is not equivalent. The last example you add in your question of course is easy to obtain, but the key in my case was obtaining $t_1$ exclusively in terms of $x$, avoiding $k$ and $r$ if possible. – iadvd Oct 04 '16 at 02:06
    One of the implications of the last equation is that if $t_1$ is a function of $x$, that equation does say that $t_1$ is the same function as the function on the left-hand side. Since it is impossible to know exactly what function is on the left-hand side without knowing $k$ and $r$, it is impossible to know $t_1$ without knowing $k$ and $r$. This is really just an incidental remark, however, since I think we've already decided you didn't really mean the two sides of the equation were the exact same function. – David K Oct 04 '16 at 02:25
EDIT: As pointed out in the comments, no solution would work for all x, since the first one grows exponentially, and the second one is a polynomial. This method, however, would give a solution at a given point x.
That substitution is correct, but the argument not fully complete. What you have found at this point is two functions $f$ and $g$ so that:
($f-g$)' = 0
At this point, you can integrade the result, and get that $f-g=c$, where $c\in\Bbb N$ is a constant. Since your equation allows for choosing that constant (i.e. choosing $c=k+t_1r$), then any choice of $k$ and $r$ that would satisfy $c=k+t_1r$, would be a legitimate solution.
Also: note that the reason the other so-called counterexamples exist, in the comments and the other post, is that those counterexamples do not allow you to choose the constant $c$. If they did, then they too would give a solution to the problem.
Alex
  • 2,449
  • thank you again for your answer. I will verify the validity by testing the resulting values of the substitution. I know the expected results so I can initially verify if the substitution provides the same results as expected. – iadvd Oct 04 '16 at 00:51
    Note that I misread the problem. In your case actually, you will have $c=k+t_1r$; so there will be several choices for $k$ and $r$. – Alex Oct 04 '16 at 00:54
  • @iadvd What you did actually is not consistent with this answer, because you treated $t_1$ as a constant when taking the derivative of $t_1(x^2 + r)$, but then it turns out you needed $t_1$ to be a function of $x$. – David K Oct 04 '16 at 00:55
  • @DavidK I assumed that he was looking for a solution at a point $x$ in this case. Of course, no solution would work for all $x$, since the first one grows exponentially, and the second one is a polynomial... – Alex Oct 04 '16 at 00:57
  • @DavidK again that is a very nice and keen point, if $t_1$ is finally a function of $x$, it would also be derived when $dx$ is applied. As Alex says in the next comment to yours, I am looking for a solution at some specific points of $x$. Now with your feedback I am starting to think that probably this will not be the case in which I can apply derivative to both sides. I will do some tests to verify what happens when I apply the substitution. – iadvd Oct 04 '16 at 01:04
    @iadvd So after checking the answers myself, here is what goes wrong. You assume $t_1$ is in $\Bbb N$, and since you are multiplying by $\ln 2$, for most $x$ it will not be. If you drop the assumption that $t_1$ and $r$ are in $\Bbb N$, then this would give a legitimate solution. – Alex Oct 04 '16 at 01:12
What is a derivative? Let $f$ be defined on an open $I \subset \mathbb{R}$ and fix $c \in I$. $f$ is differentiable at $c$ if and only if there exists a real number denoted $f'(c)$ such that $f(x) = f(c) + (x-a)f'(c) + o(x-a)$. It's easy to see, therefore, that the derivative is a "local" property. It matters not only on the value of $f$ at $c$, but at a neighbourhood of $c$.
What does this have to do with your question, you ask?
Suppose $f$ and $g$ are differentiable. If $f(a) = g(a)$ for some $a \in I$, then $f'(a) = g'(a)$ needn't be true for any $a \in I$. For example, if you have $x + 1 = 2$, this has a solution $x=1$, but the derivatives of $g(x) := 2$ and $f(x) := x+1$ never coincide.
On the other hand, if $f(a) = g(a)$ for some $a \in I$ and for each $a$ satisfying $f(a) = g(a)$ there is a $\delta$ such that $f(x) = g(x)$ for all $x \in (a - \delta, a + \delta)$, then we can definitely say $f'(a) = g'(a)$ for all such $a$.
Of course, if $f$ and $g$ are differentiable and equal everywhere then the above holds clearly and hence $f' = g'$ for all $x \in \mathbb{R}$.
