I am having a bit of trouble with constructing the biijection here. I know that the bijection has to be a piecewise function with one component being $f(x) = x$ when $x$ does not equal $1/n$. But the other component is a bit more tricky, none pass the horizontal line test. Could the other component be $2/n+2$ or how would I go about figuring that component out?
Asked
Active
Viewed 325 times
1Your question title obscures your actual question—$S$ and $T$ are out of context. Are you trying to find a bijection between $[1,2]$ and $[1,2)$? – Matthew Leingang Sep 26 '16 at 12:47
Yes, that is exactly what I am trying to do. Sorry, english isnt my native language. – Aggrawal Puja Sep 26 '16 at 12:50
No problem. I took the liberty of editing the question title to declare the variables. – Matthew Leingang Sep 26 '16 at 12:58
You can construct a bijection from $S$ to $T$ by saying that
$$2\mapsto 1+\frac12\\ 1+\frac12\mapsto 1+\frac13\\ 1+\frac13\mapsto 1+\frac14\\ \vdots$$
and that $x$ maps to $x$ if $x\notin \{1+\frac1n, n\in\mathbb N\}$
5xum
- 123,496
- 6
- 128
- 204
1Map every irrational number to itself. The rational numbers are countable so we can list the rational numbers in [1, 2], starting with 2. Then map the nth rational on that list to the n+1 rational. – user247327 Sep 26 '16 at 13:00
I like to call this the Infinite Hotel bijection; room $n$ corresponds to $1/n$ ($1+1/n$ here) and the bijection leaves only room 1 vacant. – Parcly Taxel Sep 26 '16 at 13:03
So would this be a piecewise function if im writing in function notation? Where one function is f(x) = x and another function is 1+1/n where x=1/n? – Aggrawal Puja Sep 26 '16 at 13:08
The usual Hilbert hotel argument works this way: split $[1,2]$ as $[1,2]\cap\mathbb{Q}$ and its complement. Do nothing on the complement, just leave the elements where they are. Consider that $[1,2]\cap\mathbb{Q}$ is a countable set, and enumerate its elements as $2=q_0, 1=q_1, q_2,q_3,\ldots$. On $[1,2]\cap\mathbb{Q}$, consider the map $\varphi$ that sends $q_k$ into $q_{k+1}$. This is an invertible map between $[1,2]\cap\mathbb{Q}$ and $[1,2\color{red}{)}\cap\mathbb{Q}$.
Jack D'Aurizio
- 353,855
