The field $\mathbb{C} $ of complex numbers is well-defined by the Hamilton axioms of addition and product between complex numbers, i.e., a complex number $z$ is a ordered pair of real numbers $(x,y)$, which satisfy the following operations $+$ and $\cdot$:
$ (x_1,y_1) + (x_2,y_2) = (x_1+x_2,y_1+x_2) $
$(x_1,y_1)(x_2,y_2) = (x_1x_2-y_1y_2,x_1y_2 + x_2y_1)$
The other field properties follow from them.
My question is: Is there a problem in defining complex number simply by $z = x+iy$, where $i² = -1$ and $x$, $y$ real numbers and import from $\mathbb{R} $ the operations? Or is this just an elegant manner to write the same thing?
DouL
  • 384
Pierre
  • 349
    Theoretically there COULD be a problem. Just imagine that you would define a new kind of numbers by $w=x+iy+jz$, where $i^2=1$, $ij=0$ and $j^2=-1$ (and $x,y,z$ are reals). Then you would be able to conclude that $0=\left(ij\right)^2=i^2j^2=1\cdot \left(-1\right)=-1$ in your new number system. This, of course, makes sense only if you take care to distinguish your new numbers from the old (real) ones, as the reals don't satisfy $0=-1$. This doesn't happen with the complex numbers, and this is something you must prove (even if it's easy) - you can't just pretend that it is obvious a priori. – darij grinberg Nov 23 '11 at 01:50
There is no "explicit" problem, but if you are going to define them as formal symbols, then you need to distinguish between the + in the symbol $a$+$bi$, the $+$ operation from $\mathbb{R}$, and the sum operation that you will be defining later until you show that they can be "confused"/identified with one another.
That is, you define $\mathbb{C}$ to be the set of all symbols of the form $a$+$bi$ with $a,b\in\mathbb{R}$. Then you define an addition $\oplus$ and a multiplication $\otimes$ by the rules
$(a$+$bi)\oplus(c$+$di) = (a+c)$ + $(c+d)i$
$(a$+$bi)\otimes(c$+$di) = (ac - bd)$ + $(ad+bc)i$
where $+$ and $-$ are the real number addition and subtraction, and + is merely a formal symbol.
Then you can show that you can identify the real number $a$ with the symbol $a$+$0i$; and that $(0$+$i)\otimes(0$+$i) = (-1)$+$0i$; etc. At that point you can start abusing notation and describing it as you do, using the same symbol for $+$, $\oplus$, and +.
So... the method you propose (which was in fact how complex numbers were used at first) is just a bit more notationally abusive, while the method of ordered pairs is much more formal, giving a precise "substance" to complex numbers as "things" (assuming you think the plane is a "thing") and not just as "formal symbols".
Arturo Magidin
  • 398,050
There is a completely rigorous way to do the construction you allude to in the last paragraph, namely by means of quotient rings. Indeed, $\mathbb{C} \simeq \mathbb{R}[X] / (X^2 + 1)$. This generalises, for example, we can construct a commutative ring with elements of the form $x + y \epsilon$, where $\epsilon^2 = 0$. The ring so constructed is emphatically not a field, but it is sometimes useful for doing symbolic differentiation.
Zhen Lin
  • 90,111
Just set $i=(0,1)$ and $x=(x,0)$ for any real $x$, and the notation $x+iy$ is just a shorthand for the ordered pairs notation.
Of course you could also choose $i=(0,-1)$ ........
Andrea Mori
  • 26,969
  • Hi @Andrea. Yes, we can obtain the notation x+iy from the axioms. But it would be wrong defining first z=x+iy and import the addition and product from real numbers? I mean, there's a big mathematical fault in that idea? – Pierre Jan 26 '11 at 18:25
  • Ok, I think that now I see better the spirit of your question. I believe that Arturo Magidin's answer fully explains the problems with your point of view. Another important approach is that given in Zhen Liu's answer. It is a useful exercise to show that the two strategies to define the complex numbers produce the same object. – Andrea Mori Jan 26 '11 at 19:58
    @Pierre: The problem is what does "x+yi" mean? Does it denote an "expression" or simply an ordered pair, or what? See my post here for much more on this, including a jaw-dropping exchange between Cauchy and Hankel on the foundations of complex numbers. – Bill Dubuque Jan 26 '11 at 20:13
  • @Bill Dubuque: Thanks for the reference, I'll read carefully as soon as I can. – Pierre Jan 26 '11 at 20:55
