There are some people defined the hypothesis of discussing derivative of a function $f:E\rightarrow\mathbb{R}$ at $c$ to be that $c$ must in $E$ and be a limit(cluster) point of $E$, namely $c\in E\cap E'$, rather than simply put $E$ is an open interval containing $c$. I think there should be some terminology just describe this kind of the point. (e.g. $c$ is a XX point of $E$.) I have several analysis books, but didn't find one.
Another question, due to the difference of the definition of the derivative in terms of difference requirement on $c$. There are really some different description of the consequent theorems may occur. For example, if one takes the definition that $c\in E\cap E'$ in order to discuss the derivative of a function, than $f:[0,1]\rightarrow\mathbb{R}$ defined by $f(x)=x$ is differentiable at $1$, but if adopting the definition just like in the introductory calculus book(open interval containing $c$), then he should have slightly change the definition, or give another new definition(e.g. defining a one-sided derivative) in order to make the function be differentiable at $1$. And also, if one adapts the former, a common theorem in calculus that "if $f$ is differentiable at $c$ and $f$ has a relative extremum at $c$, then $f'(c)=0$" should be rewrite, since $f:[0,1]\rightarrow\mathbb{R}$ defined by $f(x)=x$ suits the antecedent, but $f'(1)\neq 0$. I haven't learned PDE or functional analysis or other advanced courses yet, so I don't have the whole picture and view to figure out which is better.
