Ok so here is a combinatorial problem that I thought of.
Suppose N is in $\mathbb N$ such that $N>1$, then there is a way to count (set an index) to all pairs $(i,j) \in \{1,\dots,\mathbb N\}\times\{1,\dots,\mathbb N\}$ such that $i<j$. This problem is the same as the problem of setting a unique index to the edges of a complete undirected graph with $N$ vertices. In total there are $N(N-1)/2$ such pairs and the counting function can be given by $$f:S\rightarrow \{1,\dots,N(N-1)/2\} \qquad f((i,j)):= \sum_{k=2}^i (n-k+1) + (j-i)$$ where $S := \{(i,j) : 1\leq i,j\leq N$ and $i<j\}$ and those under the summation notation is ignored if $i=1$. This function is a bijection and you do get for a pair $(i,j)$ a unique number $f(i,j)$ less or equal to $N(N-1)/2$. The question is how to find the inverse of this function, i.e. if $x$ is a number in the image of $f$ then what is the $(i,j)$ associated to $x$. In other words, given the index of the edge can I easily find the pairs that present the vertices of the complete graph. You will end up with a quadratic equation with respect to $i$ but the condition $i<j$ will also give us a $j$. But what is the formula for the inverse of $f$?
