I am trying to write a shifted exponential function as a power series. I am aware of the power series definition of the exponential function, i.e. $e^{-x}=\sum_{n=0}^{\infty}\frac{(-x)^{n}}{n!}$. However, for this application, this definition is not as useful for reasons I will not go into detail about.
That said, I want to come up with a power series representation for the following shifted exponential function
\begin{equation} y = e^{-a(gx-b)^{2}} \end{equation}
The following is what I have done...
Taking the derivative of $y$ w.r.t. $x$ allows for the following differential equation to be derived.
\begin{equation} y'+2ag(gx-b)y = 0 \end{equation}
Setting this up as a power series gives
\begin{equation} \begin{aligned} 0 &=\sum_{n=1}^{\infty} n \,c_{n}(gx-b)^{n-1}+2ag\sum_{n=0}^{\infty}c_{n}(gx-b)^{n+1}\\ &=\sum_{n=0}^{\infty} (n+1) \,c_{n+1}(gx-b)^{n}+2ag\sum_{n=1}^{\infty}c_{n-1}(gx-b)^{n}\\ &=c_{1}+\sum_{n=1}^{\infty}\left((n+1) \,c_{n+1}+2ag\,c_{n-1}\right)(gx-b)^{n} \end{aligned} \end{equation}
Setting the coefficients equal to zero gives a solution for $c_{1}$ and a recurrence relation
\begin{equation} \begin{aligned} c_{1}=0 & \quad\quad\text{for} \ n=0\\ c_{n+1} =-\frac{2ag}{(n+1)}c_{n-1} & \quad\quad\text{for} \ n=1,2,3,\dots \end{aligned} \end{equation}
If I start plugging values for $n$ into the recurrence equation I get
\begin{equation} \begin{aligned} n=1\to\quad &c_{2}=-\frac{2ag}{(2)}c_{0} &&\\ n=2\to\quad &c_{3}=-\frac{2ag}{(3)}c_{1} &&=0\\ n=3\to\quad &c_{4}=-\frac{2ag}{(4)}c_{2} &&=\frac{(2ag)^{2}}{(4)(2)}c_{0}\\ n=4\to\quad &c_{5}=-\frac{2ag}{(5)}c_{3} &&=0\\ n=5\to\quad &c_{6}=-\frac{2ag}{(6)}c_{4} &&=-\frac{(2ag)^{3}}{(6)(4)(2)}c_{0}\\ \end{aligned} \end{equation}
This recurrence relation can be solved to be
\begin{equation} c_{2k}=\frac{(-2ag)^{k}}{(2k)!!}c_{0} \quad \text{for} \ k=1,2,3,\dots \end{equation}
which gives a power series solution for the shifted exponential
\begin{equation} e^{-a(gx-b)^{2}} = c_{0}\sum_{k=1}^{\infty}\frac{(-2ag)^{k}}{(2k)!!}(gx-b)^{k} \end{equation}
Here is my question: How do I solve for $c_{0}$? Sorry if this is a simple question but I couldn't figure it out.
